Camshaft install pricing (average}
I did polished LS6 heads and LS6 intake and dynatech longtubes myself a month later for $2500 more.
The heads were a lot of work, but I understand where you are coming from as you won't have to remove all the crap in front of the engine.
The heads were a lot of work, and stress, but I was already doing the intake and headers, so pulling the heads wasn't that much further.
I sold my LS1 intake and LS1 heads to recoup some of the costs. I'd say all in all it cost me about $4000 total. I'm pretty happy with the results. Still on the stock, ticking-time-bomb, 97 clutch though.
I have been quoted $700 from 3 different shops.
I was charged $1800 for a Heads, Cam, Springs, Pushrods, Gaskets, Oil pump, differential, tranny, DTE brace, ARP rod bolts(they pulled the entire motor for this), roller rockers, fast 90 intake, 90mm TB, vararam, and UDP all installed.
A cam swap takes 6 to 8 hours...here at the shop I use in CA the hour rate is $90. for 8 hours it would be $720.00 + what's needed for fluids. Tune is included. My .02
You can get a ECS Custom Cam Only for $399, or ECS Custom Cam and Comp 921 Spring Kit for $995 or:
Complete Kit Installed $2995 Includes:
ECS Custom Cam of choice
Comp Cams 921 springs
Comp Cams Titanium retainers
New Valve seals
160 degree thermostat
NGK TR-5 plugs
ASP Under Drive Pulley
GM crank bolt
2 new belts
Ported oil pump
Ported throttle body
Front main seal
Water pump gaskets
Double roller timing chain
Full Dynotuning
