Brakes pulled to right...hard!
Old Jun 13, 2008 | 08:10 AM
dcd58's Avatar
dcd58
Default Brakes pulled to right...hard!
Would any know why the front brakes would pull hard to right (or either side) after decelerating hard? Mine did last night and scared the living out of me!
Old Jun 13, 2008 | 09:16 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
There are several possibilities.
The road you were on could have been uneven or had some ruts.
Your suspension is out of alignment. When is the last time you had your car aligned?
Old Jun 13, 2008 | 09:40 AM
yakisoba's Avatar
yakisoba
Could be lots of things. Does the car pull right while not under braking? If it's only under braking, then perhaps the left side is not clamping with enough force? Any fluid leaks? Check alignment? Track the car much? Anything that may have knocked the fronts out of alignment?
Old Jun 13, 2008 | 10:05 AM
dcd58's Avatar
dcd58
Thanks..It's been awhile since my last alignment..I'll do that first!
Old Jun 13, 2008 | 10:09 AM
striper's Avatar
striper
I would check the ABS system, the EBCM might be failing.
Old Jun 13, 2008 | 10:28 AM
dcd58's Avatar
dcd58
I get no codes...wouldn't that throw a code?
Old Jun 13, 2008 | 10:29 AM
dcd58's Avatar
dcd58
I would like to mention that I always drive with the traction control always off..if that matters
Old Jun 13, 2008 | 03:01 PM
Independent1
St. Jude Donor '08
^^Should not matter. Traction control is for controlling acceleration. ABS system is for controlling brakes.
Old Jun 13, 2008 | 04:49 PM
ssmith512's Avatar
ssmith512
Brake pull can be caused by:
Low tire pressure on the side of the pull (but would also most likely cause a pull when cruising)
Faulty brake caliper on side opposite of pull
Car out of alignment (it has happened to me - car would drive down the road fine but would pull HARD under braking). I think it was front camber being way off from left side to right side (too much cross camber).
Old Jun 13, 2008 | 05:53 PM
gpracer1's Avatar
gpracer1
If none of the above, maybe you just hit a patch of slicker pavement on that side, or sand, etc.
To Brakes pulled to right...hard!
