97 killing alternators
Old Jun 14, 2008 | 02:29 PM
screamindman's Avatar
screamindman
Default 97 killing alternators
My daughter has a 97 coupe that keeps killing the batteries and alternators. Need suggestions, quick.
Old Jun 14, 2008 | 03:21 PM
screamindman
Any takers?
Old Jun 14, 2008 | 03:23 PM
madman91's Avatar
madman91
I have very little knowledge on the electrical issues, sorry.
Can anyone help out on this issue?
Old Jun 15, 2008 | 02:03 PM
tigerman's Avatar
tigerman
My 97 is acting goofy to..........tighten the wire connections on the starter but make sure you disconnect the battery before u do this....and clean and tighten all the grounds.........
Old Jun 15, 2008 | 05:08 PM
wildbadbill's Avatar
wildbadbill
if she's killing both alter. and battery than I'd look at short on the wire from alt. to the starter and than from starter to the battery.Also,the bad alternator can discharge the battery thru internal short....
Old Jun 15, 2008 | 11:33 PM
bestvettever's Avatar
bestvettever
Default Alt Problems
Hi, need a little more detail to help on this.
Exactly what is happening, did you replace battery, or test it. Did you check the charging system and measure it. Have you replaced anything and how often.
Many possibilities, but a good place to start is making sure that you have a good load tested battery, and with making sure that the cables are clean and tight to both sides of the battery, and starter, and fuse block. and the connections to the alt are clean and making proper contact. If all that is good, check the connections to the PCM, it is down in the pass side wheelwell, and is accessed by removing the access panel in the well, disconnect the battery before disconnecting and inspecting for cleanliness the connectors going to the PCM, and reinsert them carefully and tightly.
Good Luck
Old Jun 16, 2008 | 12:25 AM
sothpaw2's Avatar
sothpaw2
Make sure you have good grounds. Make sure you are not using aftermarket alternators.
To 97 killing alternators
