help...traction control/abs light
Old Jun 24, 2008 | 11:59 AM
chaase's Avatar
chaase
St. Jude Donor '12
Originally Posted by D-Ramey
pm sent...and thank you guy's for your help.. and all the other codes i listed on this thread are they fine?>is it just the abs/traction control thing that i need fixed? i cleared all the codes but one of the t/c codes want clear it pops right back up...so i guess its time to send the ecbm or w.e its called out to get fixed
The EBCM code is the one causing the problem. If cleaning up the grounds doesn't work, send the unit out and get it repaired. If you are reasonably good with tools, its an easy repair.
Old Jun 24, 2008 | 03:54 PM
D-Ramey's Avatar
D-Ramey
ok cool...ill do that whenever i get time..lol and i wish there wuz a better pix of the ebcm...but its alight ill find it...
