Didnt break into 12's with headers/tune
Temperature: 76
Humidity: 80%
Pressure: 30.02 in.
Dew Point: 62°F
April 15th Tonights slip
60' 2.071 [] 2.153
330 5.636 [] 5.782
1/8 8.529 [] 8.709
MPH 84.78 [] 82.99
1000 10.980 [] 11.182
1/4 13.055 [] 13.362
MPH 107.65 [] 107.20
Why would my times and mph be so slow? Anyone have any ideas? Also, what would the DA have been tonight with
If you can, post a copy of your tune or e-mail. I will take a look. Some times a second pair of eyes helps.
Ed
Just go out another night before you get too worked up over the numbers. Just answer this simple question, does the car feel stronger?
I've been to Atco and run 12.89 with just a vararam. My buddies GTO was running 13.5 that day. Went on another night, with no changes to the car and best I could manage was 13.1, and my friend couldn't even make it into the 13's, pulling low 14's all night.
Air, track prep, and even a bit of luck all add up in your favor sometimes, against you at other times. Now, if you go another time and your getting consistant sucky results, than start to look at your tune.
Just let me know when your going down again and if it's after my break-in I'll try and meet ya.
Ed,
Very gracious for you to look at his tune, but Dave had a local tuner do the updates and would have to get the file from him.
I'm still thinking about buying a copy of HPTuners for my own use.
Temperature: 76
Humidity: 80%
Pressure: 30.02 in.
Dew Point: 62°F
60' 2.071 [] 2.153
330 5.636 [] 5.782
1/8 8.529 [] 8.709
MPH 84.78 [] 82.99
In worse air (alot worse if you were negative D/A previously) you went almost the same MPH as your previous best. That means you are in fact making more power. As others have stated, ET improvements are mainly found in the bottom of the run (launch technique, available traction and track prep, and a little good (or bad) fortune).
What I find interesting is the fact you where down close to 2 MPH in your eighth mile times but made up most of that in the last half of the run. While the only way to know is to have logged the run, I think the warmer weather may have caused some slight knock events and the computer was pulling timing out the first half of the run slowly feeding it back in (thats what it does) during your trip down the back half of the run (hence the trap speed being almost the same). That could be from a tune that was maximized in cooler conditions when this type of thing wasn't a factor. It just might take a little less sensitivity in the knock sensors. All of this is purely hypothetical on my part but the bottom line is the more tools you have at your disposal (as you get more serious about this hobby), such as a scanning tool to data log the run....a wideband O2 sensor installed, etc. etc., its a lot easier to diagnose what may have happened.
Also, get a cheap weather station....they fit in your pocket and work great. No more guessing how good or how bad the air is on any given track outting. Once you get one you will feel naked at the track without it. They are only a couple of hundred dollars....makes a nice birthday gift or something from the wife....LOL
Kestral is the company that manufactures them....use Google search for more info....you can buy them on this country's favorite auction site as well.
Good luck with the car....a year from now and $5000 dollars later your next post will read "just missed getting into the elevens"
It never ends....may as well accept it and start buying the supporting "tools" you need to make your life easier now!
Cheers,
Tony
that's always good idea.
But I don't know how to put this any nicer... but your launches are just plain crappy. Your trap MPH says you are putting out -at least- factory HP... and with factory HP you can cut 1.9x to 2.0 60' times on factory tires.
A good "rule of thumb" is that for every tenth you shave off in the 60'... you'll likely get one-and-a-half times off at the end of the 1/4.
take your 13.31 with 2.2 60'...
if you lower your 60' by two tenths... that would equate to 3 tenths total off the 1/4... and would put you at 13.01 ET
Lower your 60' by 3 tenths and you'll then be in the 12.9x.
2.0 60' can be reached by any stock C5 on factory tires.
"Tunes" are always good
But IMO your problem is elsewhere (in the launch).
ran a 12.5 with headers,xpipe, intake and tune.
ran a 12.2 with above mods and 4:10 gears.
car has potential with a drag radial burnout and great launch for high 11's.
the c5 is an amazing car
seat time and improved launches and shifts will aid you in what you are looking for too.
~ nick
Cheers,
Tony
