front parking light
Old Jun 22, 2008 | 10:52 PM
DMan 01''s Avatar
DMan 01'
Default front parking light
My front parking light is out. 01' vert. What all is involved in getting to that bulb to change it out?
Old Jun 22, 2008 | 11:35 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
The easy way is to pop the hood, manually raise the headlight, remove the black trim plastic, the head light cover, then stick your arm down to the turn signal bulb. Watch the rubber gasket but it will prolly stick to the bulb socket.
Option 2. Remove the cover underneath the car flat on your back and reach up into the cavity to the bulb socket.
Old Feb 26, 2011 | 08:57 AM
loungnlizard's Avatar
loungnlizard
6th Gear
Great! The forum has already helped me. Last month I paid the dealer about 50 bucks to do this, now I can do this myself. Already luv this forum.
Old Feb 26, 2011 | 10:13 AM
jrose7004's Avatar
jrose7004
I use the access panel below.
Old Feb 26, 2011 | 10:26 AM
canada99vette's Avatar
canada99vette
I just raise the hood, raise the light with the switch (turn them on then back to park and the light will stay up without the headlight being on) remove hood bumper bolt (not sure what it is called bit it is a adjustable bolt with a rubber bumper on top) reach down and remove bulb. You will have to install with one hand which can be fun. Mine kept on blowing because there ended up being a hole in the top of the marker light letting water into the lens. Apparently it is common for the bulb heat to melt a hole in the top of the housing.
Old Feb 26, 2011 | 10:24 PM
rickhimar's Avatar
rickhimar
Default Watch this video
It really works
http://www.youtube.com/watchv=BaUEoD...layer_embedded
Old Feb 27, 2011 | 09:40 AM
NEREVOLUTION's Avatar
NEREVOLUTION
Push the intake for the brake cooling vent aside and you will be able to reach the bulb, easy, just did it on my 00 FRC.
To front parking light
