headlites uo/down adjustment?
Old Dec 24, 2001 | 12:39 AM
maninblack's Avatar
maninblack
Default headlites uo/down adjustment?
how to adjust the height of the shine?
thz :confused: :cheers:
Old Dec 24, 2001 | 12:44 AM
maninblack's Avatar
maninblack
Default Re: headlites uo/down adjustment? (maninblack)
Oops.I meant up/down :smash:
Old Dec 24, 2001 | 12:46 AM
C5Cemo's Avatar
C5Cemo
There are some black round ***** on the back of the headlight assembies that are easily visible with the hood up. They'll adjust the height of the assys...
Old Dec 24, 2001 | 12:52 AM
maninblack's Avatar
maninblack
Default Re: headlites uo/down adjustment? (C5Cemo)
thz
Old Dec 24, 2001 | 11:39 AM
bparker's Avatar
bparker
FYI - Those "black" ***** are to manualy raise the head lights when the motor fails.. not for adjustment...
Old Dec 24, 2001 | 03:36 PM
C5Cemo's Avatar
C5Cemo
Default Re: headlites uo/down adjustment? (bparker)
I was under the impression that you could make small height adjustments with these. I have done just that with only good results.
Do you have anymore info from your perspective? Is there another way to do it? Will the assys. become damaged in some way by over adjusting with these *****?
Old Dec 24, 2001 | 05:00 PM
GTXgp's Avatar
GTXgp
I was just about to ask the same question.
From my experience with other GM vehicles, there is usually a small torx nut that you turn to adjust the beam pattern. Last night I was poking around with the headlight assembly and if you look at the inside of the headlight assembly with the headlights up there is a small "window". You can use a quarter to turn it and it comes off exposing the back of the headlights themselves and viola there is the torx nut that I'm familiar with. From my initial impression this is what *should* adjust the headlight beam up/down...but I turned it several times in both directions and while it turned it made no difference what-so-ever in the beam (I was adjusting it while shining on my garage to see difference).
So, I'm at a loss here. Every late-model GM vehicle I've worked on has used this exact same size torx nut to adjust the beam but it doesn't seem to do squat. Is it just my car?
Adam G
Old Dec 24, 2001 | 05:08 PM
C5Cemo's Avatar
C5Cemo
Default Re: headlites uo/down adjustment? (GTXgp)
Adam- I agree with your POV. I am kinda confused if the question was about adjusting the entire assemblies or the light beam, though.
From re-reading his initial post, I think you just answered his question :D
[Modified by C5Cemo, 3:10 PM 12/24/2001]
Old Dec 24, 2001 | 05:59 PM
GTXgp's Avatar
GTXgp
hehe, I may have answered his question...but leaves me out in the cold... cause I made several turns of those torx bolts and it didn't adjust anything :confused:
Adam
Old Dec 24, 2001 | 06:38 PM
C5Cemo's Avatar
C5Cemo
:confused: I've never needed to adjust them but I thought those were the adj. screws, too :confused:
Old Dec 24, 2001 | 06:53 PM
GTXgp's Avatar
GTXgp
Well, I'm 99% sure those are the correct screws. I don't really NEED to adjust them...they are perfectly aligned... but I like to angle my headlights up just a hair from their stock position. I do that with all my cars, its just a thing :crazy: So I guess it really doesn't matter...
Adam
[Modified by GTXgp, 4:54 PM 12/24/2001]
Old Dec 24, 2001 | 08:59 PM
maninblack's Avatar
maninblack
for everyone info. I am asking how to adjust the actual headlite unit,not the
headlite assy.,i need to aim the headlite unit abit higher and not the flip/flop
headlite assy..underneath the black disc on the headlite cover is for adjusting
the headlite sideways,not up down.
My question is how to adjust the HEADLITE and NOT THE HEADLITE ASSY.
Thz, I think I will find out myself :mad :rolleyes:
Old Dec 24, 2001 | 09:13 PM
Paradigm's Avatar
Paradigm
I gave you a link for aiming in your other post - http://forums.corvetteforum.com/zerothread?id=205919
Old Dec 25, 2001 | 12:15 AM
maninblack's Avatar
maninblack
Default Re: headlites uo/down adjustment? ('98 Six Speed)
'98 Six Speed: thz for the link, It doesmt tell me how to adjuist the height for the headlite,but thz
.I actually took out the black cover and looked for myself,the adjustment screw
is actually attached to a thin metal rod which lies right in front of the lite bulbs
(hard to miss) :cool:
To headlites uo/down adjustment?
