Will install headers soon...what should I expect?
Old Jun 23, 2008 | 09:51 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default Will install headers soon...what should I expect?
I have a full Dynatech set and I want to put them on this month. Should I expect any issues like codes? Will I need a computer tune afterward, or can I simply go with it as is? I have a 97 with Corsas and a Halltech cold air. I am pondering having the headers coated prior to install.
Old Jun 23, 2008 | 10:03 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
It might not cause you problems, but in order to take full advantage of any mod, you need a tune. If you have plans to add anything else, add it and then get your tune.
Old Jun 23, 2008 | 10:49 PM
jedblanks's Avatar
jedblanks
You'll need a tune, mainly to turn off rear o2 codes. You may also get front codes, but it is less likely if you carefully tape the wires + extensions away from hot things and sheild them with heat wrap tape.
As far as what else to expect? LOUD. and SMILE.
Old Jun 24, 2008 | 12:03 AM
cruzc5frc's Avatar
cruzc5frc
not sure about dynamax but ARH were a pain to fit.. its like a puzzle tryin to get htem up.. almost swore they wouldn't go untill eventually they worked their way in...
Old Jun 24, 2008 | 12:07 AM
$$$frumnuttin'
Wouldn't ceramic coating the headers prevent codes due to heat effects?
Old Jun 24, 2008 | 08:58 AM
94legaleagle's Avatar
94legaleagle
Dynatechs are a GREAT fit and not bad to install - I did mine w/ the car on jackstands - as I recall, the pass side goes in from the top then down, and the drivers side goes in from under the car then up
you might need a helper, a mirror, and a snagging wire (to snag the dipstick) in order to get the dipstick back into it's hole
codes / tune wise, you can drive it for a while w/o a tune, but you will likely get air sensor codes, so at a minimum, you might want a bench tune
you will LOVE these headers
Old Jun 24, 2008 | 09:50 AM
mjorgensen's Avatar
mjorgensen
No but the coating will help keep heat in the exhaust and out of the engine compartment better.
Old Jun 24, 2008 | 02:38 PM
AFTRBRNR's Avatar
AFTRBRNR
You will definately get codes. A tune will fix that one for you. I have LG Pro LTs...The install is easy and straight forward. You will expect some low end power gains and plenty of sound pollution This will really make a catback exhaust sing a better note. It won't hurt you to not have the headers coated. I didn't bother doing it to mine and everything works out great.
Old Jun 24, 2008 | 05:36 PM
Char03's Avatar
Char03
just put these on and I get the the O2 codes, but they come and go... when i plan on doing my tune i will set them to not report..... you will absolutely love these.... i went with catted x-pipe and borla stingers.... probably the best sounding set up in my opinion
Old Jun 24, 2008 | 07:07 PM
blackula 99's Avatar
blackula 99
Consider lg street headers, they have provisions for all 4 o2 sensors
Old Jun 24, 2008 | 07:41 PM
TrchRedC5's Avatar
TrchRedC5
not to hijack the thread, but i'm also curious on what to expect. i've searched and haven't found the exact answer i'm looking for.
2001 zo6 just ordered lg streets, off road x pipe, b&b bullets.
i need to have my rear o2's tuned OUT correct?
this thread is the 1st i've read anything about any kind of o2 extensions for the front????
Old Jun 24, 2008 | 07:47 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
very odd.. No body has ever reported such a problem with ARH
Old Jun 24, 2008 | 09:42 PM
$$$frumnuttin'
I had the same observation...they would have been my first choice if I didn't get such a good deal on the Dynatechs from PFYC...a great vendor.
Old Jun 24, 2008 | 09:47 PM
$$$frumnuttin'
Regarding this tune business, is it possible to improve gas mileage? I feel my car idles too high some times, and the 97 fuel line setup might run richer than newer C5s, no? I hear guys getting way better mileage than I get, which is 20 mpg around town, and maybe 24-6 highway. I've never had it on a long trip but find it difficult to believe I could get 33 or so like some people claim. Again, can it be tuned for better fuel economy?
Old Jun 24, 2008 | 10:30 PM
motogib1's Avatar
motogib1
I would expect O2 codes such as P1153 and P420. If you car is running rich a tune will improve your fuel economy. Anyhow, the car should be street tuned for a header install.
Old Jun 25, 2008 | 06:25 PM
AFTRBRNR's Avatar
AFTRBRNR
I was getting 34 MPG with my A4 on 3.15 gears at 70MPH. Then I put in 3.73s and it dropped to 22 The price you pay to go fast
You can lean out the fuel with a tune and get more power and better mileage for sure.
Old Jun 25, 2008 | 09:20 PM
$$$frumnuttin'
Wow, that's a big reduction. I have the wimpy 2.73 gears, which I believe would yield the best fuel mileage. I would love to get 34 on my A4.
Old Jun 25, 2008 | 10:29 PM
vsocks1's Avatar
vsocks1
That doesn't sound quite right to me...34 down to 22 with just a gear change? Maybe someone with an automatic and direct experience can validate this. Sounds like something else going on also.
Old Jun 25, 2008 | 10:32 PM
AFTRBRNR's Avatar
AFTRBRNR
I had a Callaway Honker (excellent piece of hardware!!) with a full exhaust and tune. Great mileage. Then I got crazy.
When my H/C/I package is installed I anticipate mileage to go up a couple points but nothing above 25. 3.73's are very convincing gears to try out if you ever thought about gear swaps. All my friends that have driven the car love them! 3.15's were great but 3.73's have bigger muscles
To Will install headers soon...what should I expect?
