Sometimes God takes pity on us Dummy's.
Disconnected the air bridge to the Throttle Body to make sure the butterfly was not sticking, was OK. Started the motor several times, of course it would stall almost immediately. Connected everything back up, it started, reved a little and settled into a normal idle. Let it idle for 5 min for the PCM to relearn, went for a drive and it runs like a bomb again.
Dumb luck and the hand of God.
Also had a PCM 10 code which I could not find in the Service Manual.
Cheers.
Cheers.
I suspect what you're looking at when you see a PCM 10 listed is the "10" is the PCM's address on the computer network .... another example would be RFA B0 ....
The computers are displaying their address in hexadecimal .... a base 16 number system .... it is commonly used at the "assembler" level of programming because there are 8 bits in a byte, and two possible numbers in a bit (0 or 1) so a "byte" can be represented with two "hex" digits.
I saw a "personalized" plate on a car in Silicon Valley a few years ago .... it had C6 E4 on the plate .... and on the plate frame it said "EBCDIC" ..... when translated using IBM's EBCDIC character set (which uses hexadecimal numbering for characters) ....
the plate said "F U" which the DMV has on its "banned" list
Another Silicon Valley story ... there is an old Volkswagen "bug" driving around with personalized plates that say FEATURE ...... why ??? .... because in the software business whenever a customer complains about a "bug" in the software, a vendor always replies "That's not a bug .... that's a feature" .......
The Q is the PCM code causes a check engine light. I can delete the code and it stays off until restarting the engine which triggers it again??? Will have to get it diagnosed by my local garage friend.
What is the code ..... ?????
I took your previous post to mean that you saw a "10" as the code .... what are you seeing ????? Obviously you have a code if the CEL is on.
That is not a code ..... I already explained that the 10 is the computer's address on the network.
A DTC code has the following layout ..... P 1234 C
The leading letter ("P" in this example) indicates what system in the car the code applies to (P=Powertrain, C=Chassis, B=Body, U=CommUnication) .... the next four positions are numbers .... followed by either a "C" or an "H" (sometimes both) indicating the status of the code .... Current or History.
If you have the CEL illuminated you have at least one DTC set in the car. If you don't know how to display the codes ... read these instructions .......
To be more precise, we programmers call them "undocumented features."
Sorry for MY confusion. During the self diagnostic routine the 10 PCM code flashed so fast that I overlooked it and with the self diagnostic option it showed only 10 PCM - 1code.
The code is P0107 which is: Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage. May have been caused when I disconnected the air bridge and cranked over the engine.
Sorry again.
