Still Confused
Old Jun 25, 2008 | 09:15 PM
redman0204's Avatar
redman0204
Default Still Confused
OK here goes .1st i had recal done they replace locking plate . 2nd i had recal fix remove plate replace with K harness & relay . 3rd replaced BCM . OK here is the confussion . tech at dealership tell's me after replacing the BCM that the column lock motor need's to be raplaced. i was told on a thread here on CF that the K harness & relay fix and the CLB are both the samething . if this is true the column lock motor is already bypassed and should'nt be a problem . is this correct ? OR DO I NEED TO INSTALL THE CLB . please help
