Nassau Blue paint code
Old Dec 24, 2001 | 03:22 PM
bobbydene's Avatar
bobbydene
Default Nassau Blue paint code
Hi, I need help.....
I want to paint my corvette nassau blue. I was given the paint codes 23 and WA315D. GM tells me that this WA number is not listed on there computer. Could someone who has a car this color check to see if I have the right WA number? Does anyone know if nassau blue is known by a different name? I think that WA348D, called bright blue metallic is close but does not have any pearl additive in it. The body shop is ready to paint so if anyone can help me out I would be forever greatfull..
Old Dec 24, 2001 | 05:27 PM
BodaciousBlue's Avatar
BodaciousBlue
Default Re: Nassau Blue paint code (bobbydene)
Hi bobbyene, got to this website it should help with your questions on color codes and everything else. good luck :seeya
Old Dec 24, 2001 | 05:28 PM
BodaciousBlue
sorry here is the address http://www.c5-corvette.com/RPO_Codes.htm
Old Dec 24, 2001 | 07:06 PM
bobbydene's Avatar
bobbydene
Default Re: Nassau Blue paint code (BodaciousBlue)
ttt
I am still looking for WA number or any other paint code???
Old Dec 25, 2001 | 06:57 PM
bobbydene's Avatar
bobbydene
ttt
Old Dec 25, 2001 | 07:22 PM
Wt99C5's Avatar
Wt99C5
If you can't find the code, try going to the auto paint and supply shop yourself. They should be able to give you the code and show you a sample.
All you should need is the year and make of car.
Old Dec 25, 2001 | 07:45 PM
bobbydene's Avatar
bobbydene
Default Re: Nassau Blue paint code (Wt99C5)
That is the problem.. The bodyshop has no Nassau blue listed for 97-00 corvette. It must be known by a different name on the paint chip.
Old Dec 25, 2001 | 08:56 PM
John's vette's Avatar
John's vette
Cruise-In III Veteran
Cruise-In IV Veteran
The code on my car is 23U. Have seen it listed on some RPO code guides as Bright Blue. Hope that helps :confused:
Anyway, great choice of color. If there is something I can look at on my car that will help you, send me IM.
Old Dec 25, 2001 | 10:01 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
CODE 23 WA 348D Bright Blue Met.
This is the paint you want :yesnod:
Old Dec 26, 2001 | 05:26 PM
bobbydene's Avatar
bobbydene
Default Re: Nassau Blue paint code (Flyin'Brian)
Can anyone else confirm that the code that Brian gave above is the same one as nassau blue?
Old Dec 26, 2001 | 07:13 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In V Veteran
Cruise-In VI Veteran
Bob, you have mail confirming what Brian said :D & pic's too :cheers: good luck!
Old Dec 27, 2001 | 08:25 AM
Tom/99's Avatar
Tom/99
I have 23U, and WA315D as the color codes for Nassau Blue. :chevy
Old Mar 27, 2025 | 02:59 PM
petemichelle's Avatar
petemichelle
5th Gear
anybody ever find out the year of the corvette that has nassau blue? or the actual paint codee?
Old Mar 27, 2025 | 03:39 PM
lucky131969's Avatar
lucky131969
24 year old thread.
To Nassau Blue paint code
