Clutch adjustment?
Old Jun 26, 2008 | 09:37 PM
C7LOU's Avatar
C7LOU
Default Clutch adjustment?
The clutch pedal in my '03 Z06 seems to come quite a ways up before engaging. Is there any adjustment to be made for that or does it mean the clutch is on its way out?
Old Jun 27, 2008 | 12:12 PM
C7LOU's Avatar
C7LOU
Anyone?
Old Jun 27, 2008 | 12:21 PM
Oldvetter's Avatar
Oldvetter
These clutches are hydraulic and "self adjusting". That said, you may want to change your clutch fluid. Use a "turkey baster" to suck out most and replace. You can use DOT 3 Brake Fluid in the clutch.
Old Jun 27, 2008 | 12:35 PM
B-ras's Avatar
B-ras
FWIW, I thought the engagement point on my C5 was kinda high when I bought the car with 12K on the clock. Now three years later at 55K, it's at the same point and the clutch doesn't slip.
BTW- That was coming from a 4th Gen T/A, so it's not like I was comparing it to a Honda. I had to adjust my technique to use less of the pedal travel when I shift. No reason to go much past the point of full disengagement, or you're just adding stress to the TOB.
Old Jun 27, 2008 | 12:45 PM
hawks9999's Avatar
hawks9999
I have the same thing on my 04. I dont think it is an issue but is a bit annoying.
Old Jun 27, 2008 | 12:49 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default same here
I agree completely....it feels weird the full disengagement is like at the half way point...takes some getting use to....
what is the TOB?
Old Jun 27, 2008 | 12:56 PM
B-ras's Avatar
B-ras
what is the TOB?
TOB=throw-out bearing. And I'm no clutch expert, in case someone wants to chime with a different opinion. But there was a very long thread on the subject a while back, originated by Chuckster, IIRC, and that was the final verdict.
Old Jun 27, 2008 | 05:42 PM
AHP's Avatar
AHP
My '02 Z06's clutch engages near the top as well - I thought I was the only one.
FWIW, I always kick the pedal all the way to floor on every shift. No sense in potentially stressing the synchros with lazy pedaling..
Old Jun 27, 2008 | 10:23 PM
C7LOU's Avatar
C7LOU
Thanks everyone for the feedback! Sounds like it's normal and I think I'll go ahead and do the fluid change using the turkey basting method!
Old Jun 28, 2008 | 12:19 AM
rws.1's Avatar
rws.1
my '01 with 117K miles enganges near the top... has for the last 30K miles.....
Old Jun 28, 2008 | 12:32 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Lou -
Good choice - over time it does seem as though my Z has moved the engagement point slightly higher in the pedal movement, but I have no way to prove that with measurements.
I am a devout follower of the Ranger's fluid freshening technique - I use a turkey INJECTOR, the kind that come with cajun seasoning for deep frying a turkey.
best regards -
mqqn
Old Jun 28, 2008 | 12:39 AM
B-ras's Avatar
B-ras
I agree with you in theory; I'd rather wear on the clutch than the trans any day. And, FWIW, I don't ever powershift my car, even at the strip. I don't consider a few thenths worth risking trans damage, especially since my C5 is a daily driver.
However, once you've reached full disengagement of the clutch, I don't see how pushing the pedal down further saves wear on anything. If you've ever drag raced, you know that you have to find the engagement point in the pedal travel, then hold the pedal just past that point before release in order to cut a decent light. Once you have a good feel for that point in the travel, IMO, you are smoother on shifts without using the full pedal travel.
Not trying to be argumentative, YMMV, just relating my experience.
Old Jun 28, 2008 | 02:24 AM
ZeeOSix's Avatar
ZeeOSix
Original clutch at 117K ?
Old Jun 28, 2008 | 02:31 AM
ZeeOSix's Avatar
ZeeOSix
I made a bunch of measurements on my clutch pedal and engagement point when my Zee was pretty new for a baseline. I think I posted the info on the other site ... here's a few old thread on the subject.
http://www.z06vette.com/forums/f5/pe...agement-17768/
http://www.z06vette.com/forums/f5/cl...rements-34199/
Old Jun 28, 2008 | 03:09 AM
B-ras's Avatar
B-ras
Good stuff.
Without having measured, I'd say the engagement point and take up characteristics of my clutch are very close to that. Has yours changed much since then?
Old Jun 28, 2008 | 03:33 AM
ZeeOSix's Avatar
ZeeOSix
Good stuff.
No change in my clutch engagement/pedal position as far as I can tell. I have not remeasured since then, but if it changed some I'd probably notice it. I try to change the clutch fluid in the reservoir at each oil change since it only takes 10 minuted to do. I'm also pretty easy on my clutch ... never slip it and never hammer the throttle until it's fully engaged -- I let the rear tires take the abuse instead of the clutch.
Old Jun 28, 2008 | 03:45 PM
vettekidc5's Avatar
vettekidc5
Mine was original to 121k....It still had life on the disc when i removed it when I did my motor.. built the motor and put a ls6 clutch in.. With 405rwp clutch is toast in 5k miles.
To Clutch adjustment?
