Window Problems, Help!
Old Jun 27, 2008 | 10:32 AM
tgabosch32's Avatar
tgabosch32
3rd Gear
Default Window Problems, Help!
Here is the story. My passenger window wouldn't work, so I researched some common problems here, and based on the symptoms(when I pushed the button, I could hear a relay click, but the window wouldn't move. Also, it would draw a lot of current from the battery) I purchased a new window motor with regulator. When I went to have it installed, the old motor and regulator worked fine outside the car, and the click went away, and now the lock doesn't work either. So, the next move the tech suggested was to replace the door control module. We did that, and it did nothing. I am out of ideas. Someone please help.
Old Jun 27, 2008 | 10:34 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You need to get out a meter and measure voltages on both sides of the motor. If the ground side of the motor (hot and ground reverse based on direction) shows voltage, you have a resistive ground. you need to chase it back through the relays, control box etc.
