Need Help! Misfires/Check Engine!
Old Dec 24, 2001 | 06:51 PM
GTXgp's Avatar
GTXgp
Default Need Help! Misfires/Check Engine!
So I was driving this morning and started to get misfires followed by a check engine light. Since I was near the dealer I brought it over and hoped he would be open. They were, and they got it in pretty quickly. They *say* they checked the coils. Anyway, after an hour he said he still didn't know what the problem was and told me to come back Wed. I was a little hesitant to drive away with a blinking Check Engine but I did.
Brought the car home and ran an autotap on it. First, I have massive misfires on Cyl 6 even at idle.
As for the Check Engine.. I have a 0300 "Misfires Detected" in my long term log, and a 0306 in my long term and my pending. However, there is no description for the 0306. What is this code? When she cools down I might pull the plug myself but I thought I'd run this by you guys as well.
Thanks and happy holidays,
Adam G
Old Dec 24, 2001 | 07:42 PM
ohonepewter's Avatar
ohonepewter
Default Re: Need Help! Misfires/Check Engine! (GTXgp)
I recently had the same problem. The dealer diagnosed a misfire in cylinder #7. He said a computer glitch caused a misfire that resulted in a fouled plug. They reprogramed something in the computer and replaced the plug and it runs great now.
Old Dec 24, 2001 | 11:11 PM
GTXgp's Avatar
GTXgp
Default Re: Need Help! Misfires/Check Engine! (ohonepewter)
Thanks ohonepewter, now, does anyone know what the mystery 0306 code is?
Adam
Old Dec 25, 2001 | 09:09 AM
Vettepartz's Avatar
Vettepartz
My AutoTap Guide says P0306 is a "Cylinder 6 Misfire".
Old Dec 25, 2001 | 10:03 AM
olephart's Avatar
olephart
Default Re: Need Help! Misfires/Check Engine! (Vettepartz)
Yep. It's 30X - X is a number 1-8 that is the misfiring cylinder.
Hope it's something obvious. It's a complex detection scheme and finding the cause can get weird.
Old Dec 25, 2001 | 10:53 AM
RadarBlue's Avatar
RadarBlue
Could also be a wire, or a coil. One thing you could try, is swap your #6 wire with another and see if the mis-fire moves to the new cylinder. If it doesn't, then try swapping the coil packs. This should help you narrow it down. Be sure to clear the codes in the computer before each swap.
Good luck.
Old Dec 25, 2001 | 12:27 PM
Paradigm's Avatar
Paradigm
Check it out electrically (swap wires -coils) replace the plug. It could also be a broken vlave spring or rocker arm.
Old Dec 25, 2001 | 02:17 PM
GTXgp's Avatar
GTXgp
Default Re: Need Help! Misfires/Check Engine! ('98 Six Speed)
Cool thanks guys! Now onto troubleshooting... :boxing
Have a good holiday!
Adam
[Modified by GTXgp, 12:56 PM 12/25/2001]
Old Dec 25, 2001 | 02:47 PM
GTP's Avatar
GTP
Your car hates you, you must sell it ASAP and go back to Pontiac Grand Prixs :p:
Aaron
[Modified by GTP, 11:07 AM 12/25/2001]
Old Dec 25, 2001 | 03:07 PM
MDT's Avatar
MDT
Default Re: Need Help! Misfires/Check Engine! (RadarBlue)
Good luck.
RadarBlue,
You offer a sound diagnostic approach. I might add that if all of the above indicates the ignition is OK on the misfiring cylinder, try cycling (unplug and replug) the injector connection on that cylinder.
Good luck running it down, Adam.
Mark
Old Dec 25, 2001 | 11:32 PM
azarby's Avatar
azarby
Had a similar experience about a month ago. My 2001 would misfire so bad tha the whole car would shake, but it did not throw any codes. The dealer could see the missfires on their diagnostic tool at high and low RPM. The dealer ended up replacing a plug and wire, they installed a new PCM , swapped several plug wires and finally replaced another plug. So far so good.
Bob
Old Dec 26, 2001 | 01:18 AM
GTXgp's Avatar
GTXgp
Default Re: Need Help! Misfires/Check Engine! (azarby)
You aren't the first one who has said the dealer did something with the PCM, and I find that rather odd. I'm wondering if there is some kind of inherent problem with some of our PCMs? I've decided at this point I'll just bring it to the dealer (take advantage of my warranty while I still have it :smash: ) but I'll suggest a few things when I go over thanks to this thread :D
Adam
Old Dec 26, 2001 | 06:25 PM
GTXgp's Avatar
GTXgp
Default Re: Need Help! Misfires/Check Engine! (Buckmaster)
No aftermarket stuff on the car right now. I just got the car a week ago :)
I brought it in this morning. They said they checked all the usual misfire stuff. However, they have said something weird. They mentioned something about the compression on Cyl 6 and about it being lower than normal? They say they ran some type of engine flush and it brought the compression up closer to normal, but they want to do it again and let the flush sit overnight... all this sounds kinda strange to me, but I guess you have to trust that these guys know what they are doing :rolleyes:
At least crap like this happens now instead of when I have mods on the car...
Adam G
Old Dec 26, 2001 | 06:52 PM
carpe dm's Avatar
carpe dm
The "flush" procedure is probably to "de-carbon" your engine. You may have had so much gunk in there that the valves were not working properly, or the plug(s) were fouled. Good luck! :yesnod: :smash:
Old Dec 26, 2001 | 11:26 PM
Z06-Goose's Avatar
Z06-Goose
Default Re: Need Help! Misfires/Check Engine! (carpe dm)
Ask the dealer to do a leak down test. They probably did a compression test already.
Did you check the actual condition of the # 6 plug? That will tell the story.
Since you just bought the car, it's hard to determine how hard the car might have been driven. The leak down test is to see if the rings are worn out.
Old Dec 27, 2001 | 01:28 AM
MDT's Avatar
MDT
Adam G
Adam,
If the misfires are because of low compression, then I'm doubtful that any kind of a flush will cure it.....although it's possible maybe there are some rings stuck on #6 piston. I hope that it isn't because a slightly bent valve is not sealing properly. They should be able to get some good indication from a careful compression test or better yet do a leak down check on it. That certainly should pinpoint the valves or the rings and in the case of the leak down test, if it is a valve they should be able to determine whether it's intake or exhaust. Hopefully it's not something that serious where the head has to come off.
Let us know what they discover.
Good luck.
Mark
Old Dec 27, 2001 | 01:53 AM
GTXgp's Avatar
GTXgp
Default Re: Need Help! Misfires/Check Engine! (MDT)
Yeah, they say the flush didn't fix the compression completely. That's why they are letting it sit overnight supposedly.
First thing tomorrow I'll ask about the Leak Down Test.
I'll keep you all updated...
Adam
To Need Help! Misfires/Check Engine!
Old Dec 27, 2001 | 10:03 PM
GTXgp's Avatar
GTXgp
Default Update
Well, I went over and had a long talk with the service rep at the dealer this morning. He says they haven't done a leak-down test yet. At this point they've given up on electrical and carbon build-up. He said they are going to check the rods/springs tomorrow and they are hoping that's the problem. On the plus side, I got a thorough carbon-engine flush for free :jester
I'll let you guys know what they find.
Adam
Old Dec 29, 2001 | 05:42 PM
GTXgp's Avatar
GTXgp
Default Update
Well, I've had it with the stupid dealer. :mad They've had the car for 5 days and haven't touched the engine problem nor my reverse light problem. So I took the car back and picked up some rods at the parts dept before they closed and I'm about to pull the valve cover off. I'll let you all know what I find...
Adam
Old Dec 29, 2001 | 06:31 PM
MelloYellow's Avatar
MelloYellow
Default Re: Update (GTXgp)
Find a different dealer! Took me 5 to 7 GM Chevy dealers before I found a good one.
