Intake Help
Old Jun 27, 2008 | 07:31 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Default Intake Help
Below is a picture of the air intake on my car. A friend has suggested I cut two holes below the filters to allow cool air. I'm thinking holes in that shroud might severely decrease engine cooling?
Yes, I know I need to CLEAN !!!!!
Old Jun 27, 2008 | 07:33 PM
dougbfresh's Avatar
dougbfresh
Why??? The factory ducting brought cool air in already-why munge it up?
Old Jun 27, 2008 | 07:36 PM
Mark C5's Avatar
Mark C5
I was talking about cool air to the filters
Old Jun 27, 2008 | 07:55 PM
VinnyT's Avatar
VinnyT
Sure. I would cut a large opening to expose both filters to the outside air, but affix a screen to the shroud.
Old Jun 28, 2008 | 12:54 AM
bvillezo6's Avatar
bvillezo6
From: Virginia Beach VA...originally Burtonsville, MD
Considering that after market intakes such as the Callaway Honker and the one made by Breathless Performance call for making cuts in the shroud you should be fine. I agree that screens are probably a good idea though. Good Luck!
Jim
Old Jun 28, 2008 | 09:50 AM
The Wrench's Avatar
The Wrench
You could do that, or just open up the foglight screens. You can cut them by hand, buy aftermarket screens with holes in them, or use the Z06 mesh screens. all have the advantage of taking air higher up, which is cleaner. And they will hold intake air temps within 2 degrees of ambient when you are moving.
DG
Old Jun 28, 2008 | 10:21 AM
Mark C5's Avatar
Mark C5
DG
I like that idea a lot. Since I don't have fog lights, any problem just removing the plastic screen instead of cutting it?
Old Jun 28, 2008 | 10:59 AM
Mark C5's Avatar
Mark C5
On second thought I just took a look at it and it appears you need to remove the bumper to remove the fog light screens, or is there a trick I'm missing?
Old Jun 28, 2008 | 12:13 PM
c5streak's Avatar
c5streak
On the bottom of the bumper just at the front of the wheelwell, is a removeable panel with (5) 7mm screws. With it off you should be able to get to the foglight screens.
Old Jun 28, 2008 | 12:18 PM
Mark C5's Avatar
Mark C5
Thanks, I'll take a look.
Old Jun 28, 2008 | 01:08 PM
Oldvetter's Avatar
Oldvetter
I agree that the foglights "holes" are the way to go. Although I would not do this as I like a clean engine.
Note that the after market intakes such as the Callaway Honker and the one made by Breathless Performance which call for making cuts in the radiator shroud USE A HOUSING WHICH STILL ALLOWS PRESSURIZED AIR TO FLOW THRU THE RADIATOR, just cutting holes would loose a lot of air going thru the radiator.
Old Jun 28, 2008 | 01:10 PM
Mark C5's Avatar
Mark C5
That's what I was thinking
Old Jun 28, 2008 | 02:32 PM
vettekidc5's Avatar
vettekidc5
Mine has a Hole With a Lid over it, The K/N sticks directly down in the flow of air coming from the car- Like a ram air..
Its made by a company called C/R motorsports I dont know if they still are in buisness but I really do like the fact its drawing cold air, from right infront of the radiatior, and its being rammed into it.
Old Jun 28, 2008 | 02:51 PM
vettekidc5's Avatar
vettekidc5
http://www.thevettedoctors.com/pro_flow+.htm
started researching it.. I found it on a old page out there on the vettedoctors site.. Not sure if this stuff is still out but there was many many testomoines on the design back in the early c5 era.. My 99 had it on it when i bought it so I dont know..
Old Jun 28, 2008 | 05:20 PM
dndrsn's Avatar
dndrsn
"FLIP-IT" and forget about it.
To Intake Help
