engine noise question
Jun 28, 2008 | 08:52 PM
How do you know if your motor has engine knock from rods a main barring or if it is just valve train noise
Jun 28, 2008 | 09:36 PM
Valve train noise will sound like a faint typewriter. A rod noise sounds like tapping a wooden table with your knuckle.
I have the cold start piston slap which is considers normal. It goes away when warmed up.
V
Jun 28, 2008 | 09:43 PM
reply
the car has a large cam long tubes with no cats and a ghl cat back it loud. but what i hear is a tapping at idle not very load you really have to listen for it and some rattle noise when you rev the car up drained oil ran a magnet through the rag the oil was drained on and could not find any metal at all but the rattle is getting loader and you still have to listen for the tapping.
Jun 28, 2008 | 09:52 PM
Were the lifters changed when the cam was installed?
Jun 28, 2008 | 09:54 PM
reply
No the vette only 20,000 on it so we used the stock lifters from the car the car is a 02 z06
Jun 28, 2008 | 09:55 PM
Any specs on the cam? May be too large for the stock lifters/rods.
Jun 28, 2008 | 09:56 PM
reply
I do notice that the oil preasure has changed used to run at 37 psi and now it will gas low as 32 psi. Oil pump is stock.
Jun 28, 2008 | 09:57 PM
reply
Cam is a 230 230 591 591on a 114.
Jun 28, 2008 | 09:59 PM
The cam could be wearing out that stock valvetrain.
Jun 28, 2008 | 10:10 PM
reply
has after market heads with springs good to .650 lift and aftermarket push rods. Also noise is only preasent when the engine is warm not on start up.
Jun 28, 2008 | 10:16 PM
Good, then you have beefed up the valvetrain. Some ticking will be normal.
How's the oil pressure at idle and at 2000-2500 rpms? (hot of course)
Jun 28, 2008 | 10:31 PM
reply
50 psi in that range
Jun 28, 2008 | 10:35 PM
I really think you're fine. Oil pressure is good. Unless it really starts to get loud or you get some popping or misfiring, you're good to go.
V
Jun 29, 2008 | 04:08 PM
reply
Has any one with head and cam had a problem with using stock lifters going out and making a lot of noise.
