Oil Pressure Loss (NEED HELP)
Old Jun 29, 2008 | 12:05 PM
2QWK2C's Avatar
2QWK2C
5th Gear
Default Oil Pressure Loss (NEED HELP)
I have a 2001 C5 that I did heads and cam package on. After taking it out of storage I've noticed something strange. I'm losing oil pressure for about a half a second while driving, it doesn't happen all the time. I have changed the oil switch and now about to change the PCM due to a hard code (1652). Has anyone had this problem? Can someone give me some advice what to do first. Thanks
Old Jun 29, 2008 | 01:19 PM
VinnyT's Avatar
VinnyT
More details.
Is it dropping to 0 when driving or just fluctuating?
Old Jun 29, 2008 | 02:17 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
It sounds like your oil pressure sensor is going bad. Common problem.
Is the code above supposed to be P1652? Have you cleared it from the DIC to see if it comes back?
DTC P1652
Circuit Description
The PCM controls the Powertrain Induced Chassis Pitch by grounding the control circuit via an internal switch called a driver. The primary function of the driver is to supply the ground for the controlled component. The driver has a fault line which is monitored by the PCM. When the PCM commands a component ON, the voltage of the control circuit should be low, near 0 volts. When the PCM commands the control circuit to a component OFF, the voltage potential should be a high 5 volts (+/- 0.5 volts). If the fault detection circuit senses a voltage other than what the system expects, the fault line status changes causing the DTC to set.
The PCM receives an 5 volt (+/- 0.5 volt) reference signal from the electronic suspension control (ESC) module on the Powertrain Induced Chassis Pitch circuit. The PCM grounds this circuit when the vehicle accelerates rapidly or brakes hard. When the chassis pitch input circuit goes low to about 0 volts, the ESC module commands all four shock absorber solenoids to a firm position. The PCM calculates the chassis pitch information based on the engine torque and the vehicle braking force.
Conditions for Running the DTC
* Engine speed greater than 400 RPM.
* The system voltage is greater than 6 volts but less than 18 volts.
Conditions for Setting the DTC
* The PCM detects that the commanded state of the driver and the actual state of the control circuit do not match.
* The condition must exist for a minimum of 5.0 seconds.
Action Taken When the DTC Sets
* The PCM stores the DTC information into memory when the diagnostic runs and fails.
* The malfunction indicator lamp (MIL) will not illuminate.
* The PCM records the operating conditions at the time the diagnostic fails. The PCM stores this information in the Failure Records.
Conditions for Clearing the DTC
* A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
* A history DTC will clear after 40 consecutive warm-up cycles, if no failures are reported by this or any other non-emission related diagnostic.
* Use a scan tool in order to clear the DTC.
Old Jun 29, 2008 | 04:18 PM
2QWK2C's Avatar
2QWK2C
5th Gear
I had my shop trouble shoot the code and it comes back that the computer needs to be changed. Do you think that's why the oil pressure keeps jumping around?
The oil pressure drops to 0 and then goes back to normal pressure. while driving and at idle. I would have to let off the gas for it to come back up to normal pressure. Any suggestions?
Old Jun 29, 2008 | 05:01 PM
VinnyT's Avatar
VinnyT
Sounds more like a bad sensor(which they are known for) OR a faulty ground. Trust me, if you really had 0 oil pressure, your engine would sound like a typewriter.
Old Jun 29, 2008 | 05:03 PM
'VETTE PHASE
No, I don't think this has anything to do with the oil pressure, but I would do a little diagnostics, if the shop hasn't already, before replacing the PCM. That's an expensive item if it turns out not to be the problem. I would try the following:
1. Pull the code up on the DIC and see if it is a history code or a current code. If it has an h after it, it is a history code, which means it happened at some time, but is not happening now. If it has an HC or C, it is a current code and is currently happening.
2. Reset the codes and see if it comes back.
3. Try the diagnostic approach below.
Here is the diagnostic from the service manual:
Here is the pinouts for the C2 connector:
I would say this is the oil pressure sensor. It is fairly common that they go bad. If you do a search, there is a replacement sensor that goes to a Buick that is much better quality than the replacement for the corvette.
Old Jun 29, 2008 | 06:19 PM
2QWK2C's Avatar
2QWK2C
5th Gear
the shop tried to clear the code however its a hard code and it won't clear. Next step was to replace the PCM. The oil pressure guage goes to almost 0 pressure; half a second and comes back to normal. This happen at all speeds. Where is the oil pressure sensor located on this vehicle?
Old Jun 29, 2008 | 07:37 PM
'VETTE PHASE
There is no such thing as a hard code. Unless they went through all of the checks above, that are in the service manual, then replacing the PCM is not the next step.
Behind the intake on the drivers side. You have a couple of options on how to get to it. Do a search on "oil pressure sensor".
To Oil Pressure Loss (NEED HELP)
