engine wiring harness????????
Old Jun 29, 2008 | 02:09 PM
blue Z06+'s Avatar
blue Z06+
Default engine wiring harness????????
Hi All,
The shop that is building an engine for me has asked me a question that I need help with. The engine is going to be dynoed on an engine dyno and he sent me the following question. Any information that you might have would be deeply appreciated.
"Do you know if your engine harness is easily removable so we could tune your ecu on the dyno?"
I guess I should add that the car is a 99 6 speed.
Bear
Old Jun 29, 2008 | 10:07 PM
blue Z06+'s Avatar
blue Z06+
ttt
Old Jun 30, 2008 | 07:47 AM
ChopperLoco's Avatar
ChopperLoco
I would think a 'stand alone' harness would be the way to go-you can get them on e-bay.
Try this question in the scan and tune section.
Good luck-Dominic
Old Jun 30, 2008 | 09:50 AM
MattB's Avatar
MattB
I think not. I believe the issue is with the fuse box under the hood. The engine harness has several wires that go directly to it, an wires from the front harness and the dash do as well. I'm pretty sure there is no easy to get to connector that would allow you to disconnect the dash and front harness from the fuse box. Then you also have the TAC controller that would have to come out.
Painless makes a couple of LSx wiring harnesses that could be used, be sure to get the drive by wire ones though.
Old Jun 30, 2008 | 02:02 PM
ChopperLoco
Default I agree with above...
...but there are much simpler/cheaper stand alone harnesses available.
Dominic
Old Jun 30, 2008 | 11:22 PM
blue Z06+'s Avatar
blue Z06+
Dominic
Dominic
And what would that be and where do I find them?
Old Jul 1, 2008 | 07:05 PM
blue Z06+'s Avatar
blue Z06+
ttt
Old Jul 2, 2008 | 10:56 AM
CorvetteRecycling's Avatar
0CorvetteRecycling
Former Vendor
Search for the three wire harness for the LS series engines. I saw them last year at the SEMA show in vegas....they looked very nice and simple. (I cant remember who made them)
Old Jul 3, 2008 | 01:03 PM
ChopperLoco
Originally Posted by blue Z06+
Dominic
There was a guy out of NY that offered them on e-bay-but they are not there now about $300-keep checking...
Dominic
To engine wiring harness????????
