Kye Fob
Old Jun 30, 2008 | 06:05 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Default Kye Fob
I have a 2000 and the fob got tossed to me yesterday, which wasn't close, and hit the pavement. Hasn't worked since. It will beep twice when you hold it about 40 seconds but still don't work. Battery is about a month old. Any suggestions??? Change battery again??? Or what???
Thanks!!!
Old Jun 30, 2008 | 06:52 PM
MattB's Avatar
MattB
Make sure its not open and then re-train? Good luck, it sucks the 2000's are unique....
Old Jun 30, 2008 | 07:02 PM
65GGvert's Avatar
65GGvert
You can try resoldering the connections, but you'll probably need a fob. Check out Gene Culley at gmpartshouse.com. For the 2000 they're around $58.
Old Jun 30, 2008 | 07:19 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi DP77Vette -
Here is a page with pictures of fob internals - if you can solder you may find your issue inside - and if not, at least it did not cost you any more to try.....
http://www.iammoon.com/c5tech/fobs/
best regards -
mqqn
Old Jun 30, 2008 | 09:55 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Thanks guys, I'll check it out but will probably just buy another from GM Partshouse.
Thanks again!
To Kye Fob
