4 Post Auto Lift
Old Jul 1, 2008 | 04:28 PM
Daddyrama31's Avatar
Daddyrama31
Default 4 Post Auto Lift
Any one know where I can get a 4 post auto lift for the garage. Any one have a suggestion on a specific model or brand?
Old Jul 1, 2008 | 04:33 PM
MagRedConv's Avatar
MagRedConv
MD-6XP - www.gesusa.com
Old Jul 1, 2008 | 04:35 PM
hotwheels57's Avatar
hotwheels57
This has been asked/answered in numerous past posts. I'd recommend that you go into C5 General or C5 Tech, click on search this forum in the red banner.
Use keywords "four post lift" or similar. You should find many of the past discussions with images, pros/cons, pricing, capacities, options, etc.
Then, you can also do an internet search using the same keywords and manufacturers names to determine more detailed information that only the manufacturer can offer.
My advice is to buy a good USA lift, not something sold by a USA distributor, but made offshore.
Also, commercial grade lifts don't cost much more than hobby grade lifts. They're built to more heavy duty standards and used by many professional shops.
Look for a lift that is built to ALI and ETL standards and independently tested.
Find a distributor that can also quote you a delivered and installed price. Mine cost me minimal extra for that service and my homeowners insurance preferred it for coverage.
Remember, your pride and joy will occupy the lift and you (friends, family) will be standing beneath it.
Old Jul 1, 2008 | 04:55 PM
Daddyrama31
Thanks for your help and good advice.
Old Jul 1, 2008 | 08:23 PM
japc5's Avatar
japc5
There is one for sale in Florida.
http://forums.corvetteforum.com/show....php?t=2066115
Old Jul 1, 2008 | 08:48 PM
sperkins's Avatar
sperkins
Originally Posted by japc5
Jump on this one. I paid twice that for mine just last year and I love it. It's by far the best car related item I've ever bought.
Old Jul 2, 2008 | 09:53 PM
WDDarts's Avatar
WDDarts
Check out Greg Smith Equipment located in Norcross, GA. Their web site is www.gregsmithequipment.com. My friend and I both purchased the ProPark 7 LL about a year back. Looks like the ProPark 8 is what replaced it. This is one of the best investments I have made.
PM or email if you have any questions. Looks like you live close as well so if you are interested in seeing mine let me know and I would be happy to give you a demo.
Old Jul 2, 2008 | 09:58 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
At the risk of stating the painfully obvious, just keep in mind that you can't do any major work with the 4 post. You need a 2 post for that.
Old Jul 2, 2008 | 10:05 PM
WDDarts's Avatar
WDDarts
http://forums.corvetteforum.com/show....php?t=1873677
This is the link to the thread where you can see pics of my lift.
Old Jul 2, 2008 | 10:09 PM
z06 hellcat's Avatar
z06 hellcat
Old Jul 2, 2008 | 10:25 PM
av8or's Avatar
av8or
I'm considering a four-post.... mainly to stack cars. However, I also would use it for minor maintenance. How does the four-post crowd manage wheel removal? I can imagine lifting the car, placing jack stands under the inside frame jack points, and lowering the lift. Is that correct?
Old Jul 2, 2008 | 10:54 PM
itzza427's Avatar
itzza427
You can't beat a Back Yard Buddy !! They are a little pricey,but to me they are worth it VERY solid,solid 4x4 box steel tube post, heavy hydrolics and heavy and wide drive on tracks. The have a very heavy duty jacking tray that fits/slides between the treads.They are large enough to place jack stands on the treads and or the tray.I changed out the complete rear trailing arms/suspension on my old shark.Did a complete brake upgrade on a buddy's C5. Hope this helps!!
Old Jul 3, 2008 | 08:15 AM
BLOWNBLUEZ06
With a 4 post, you're not going to be able to get jack stands in the proper place. That's why I said what I said earlier. A 2 post will allow you to get to the frame and still allow you to park cars underneath.
Old Jul 3, 2008 | 08:50 AM
VetteDrmr's Avatar
VetteDrmr
As a 2-post owner, there are a couple of things about the above statement that need to be understood. First, you can get lifts for a 4-post that will pick up the car from the cross member so you can do suspension work.
Second, yes, you can suspend cars on a 2-post as long as you want and park cars underneath. However, cars aren't designed to have their weight supported by 4 pads on the frame, and you can't get good contact on the cross members with 2-post lift arms. This causes the cars to "sag" over time and causes wierd things to happen, although the effect doesn't seem to be permanent. Doors won't close correctly, for example.
All I've stated comes from direct experience with my lift. YMMV. If I had to do it again I'd get another 2-post, but I thought this might be useful to someone.
HTH, and have a good one,
Mike
Old Jul 3, 2008 | 09:37 AM
Daddyrama31
Mike, Thanks. That's why I am a member of this board. Your experience, and that of other members is priceless!!
Old Jul 3, 2008 | 10:32 AM
sperkins's Avatar
sperkins
Here's my setup:
Old Jul 3, 2008 | 12:29 PM
hotwheels57
There's still so much misinformation about the pros/cons of a two post vs a four post lift. I wonder if some of the information comes from people who've never researched the wide range of lifts/options available.
I built two frame off and one frame on tri five Chevy cars over ten years. I used both a two post and two different four post lifts in three different home shops (FORWARD MANUFACTURING, SUPERLIFT, BEND PAK). All had their advantages.
With the options available for a four post (look at the image above with the jack bridge lift), an owner/builder can do just about anything they want to accomplish with a four post.
The two post lift can sometimes pose more issues for an owner, especially with a lowered C5/Z06 car...getting down on your knees to set the arms, driving up on wood, lift arms that don't correctly contact the lifting points, etc
My current four post lift has width adjustable runways. I can get four jack stands beneath the four BMW pucks on my car, or I can use the jack bridge to lift beneath the front/rear suspension cross members. I use a two ton tripod jack or bottle jack on the jack bridge to lift beneath the cross members.
Decide what you intend to use the lift for and research every (USA manufactured hopefully!) lift that you can get material from.
To 4 Post Auto Lift
Old Jul 3, 2008 | 01:52 PM
vrybad's Avatar
vrybad
I agree with most of what you said here.
The problem with the corvette is access to the drivetrain.
Now, this only matters if you do 99.9% of the work on your own car.
I do, so a 2-post made the most sense.
Minor inconveniences, such as those you mentioned, don't bother me as much as having to work alot harder to pull the drivetrain on a 4-post.
Each user has to be VERY honest about its intended use, and then the correct choice can be made.
It is not easy at all to do this with a 4-post...
Old Jul 3, 2008 | 03:27 PM
hotwheels57
...the vast majority of Corvette owners don't do 99.9% of the mechanical work on their own cars. They have extended warranties and dealerships/independent shops to do that for them.
I dropped solid rear axles and transmissions out of my tri five cars on my four post lifts. It required some thought process, gorilla muscle, leverage and swinging the axles 90 degrees on a transmission jack. I knew the kind of work I would primarily be using the lift for and planned/purchased accordingly.
Luckily, a frame off build (or your complete drive train drop out) isn't a regular occurrence. Ideally, a large enough home shop would have a four post and a two post lift.
Most want a lift for storage or to do less extensive mechanical work as you're brave enough to tackle. For them, a four post works just great.
I liked my two post asymmetric lift for doing frame off work, but my four post lifts offer much less effort to get the car in the air and keep me off my knees and back, which is the objective of a lift (for me)...
Old Jul 3, 2008 | 04:08 PM
TooMch's Avatar
TooMch
Good post and I agree but there are ways around it if you are not going to do that type of work often. Here is a post with pics on how someone did a portion of what you show on a 4 post lift: http://forums.corvetteforum.com/show....php?t=1753571
