whould this work in a 2002 a4
Old Jul 1, 2008 | 10:52 PM
back82's Avatar
back82
Default whould this work in a 2002 a4
texas speed and performance is offering this .. will it work in a 2002 a4 is it worth it? anybody recomend cam work only.. or do most people always do heads and cam.. this cam is only 369.00 $
Magic Stick V.4 239/242, .649"/.609" Camshaft With Your Choice of Lobe Seperation (111 LSA Standard)
mods are vararam cai texas speed long tube headers. x-pipe, borla stingers. 3:42"s and tune..
Old Jul 1, 2008 | 11:03 PM
motogib1's Avatar
motogib1
I am by no means knowledgeable on cam selection but make sure the cam you select is compatible with the stock torque converter if you do not plan to change it out for a high stall converter. I have the same mods as you except I have melrose headers. I plan on having a cam installed in august so I am thinking along the same lines.
Old Jul 2, 2008 | 10:10 AM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
That cam is great Cam only, but you will need a Converter and a good tuner to make it run right
Old Jul 2, 2008 | 10:34 AM
Blow Torch's Avatar
Blow Torch
I think most guys try to run a 114 with an Auto. I THINK the 112 will need a lot of fine tuning
Old Jul 2, 2008 | 10:39 AM
black98c5's Avatar
black98c5
You'll be fine. I'm running a G5X3 112lsa in my A4 (cam only w/bolt-ons) and the car drives great. I would have went with the G5X4 had I known it would drive this well. It's all in the tune!!!
You will need a stall though. I'd recomend a Yank SS3600.
Old Jul 2, 2008 | 10:50 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
The MS4 is a very large cam, and it takes a good tuner who knows what he's doing.
Now, the duration or LSA doesn't bother me, it's the lift. .649" intake, you'll need better springs than most cam kits come with, plus you may need to flycut the pistons for that kind of lift.
Old Jul 2, 2008 | 11:18 AM
Former Vendor
If you have stock heads, no flycutting is required for the MS4. The kit Texas speed sell's with that cam comes with the correct springs
Old Jul 2, 2008 | 12:13 PM
C5XTASY's Avatar
C5XTASY
How often will those springs need to be changed out with that much lift?
Thanks,
Ed
Old Jul 2, 2008 | 12:22 PM
back82's Avatar
back82
Thanks Guys. If I Purchase That From Texas Speed And Performance. What Would Be The Going Rate For Everything I Need. Converter? Installed? If I Have Aready Purchased The Magic Stickcam From Tsp.?
Old Jul 2, 2008 | 01:00 PM
Former Vendor
If you would like to discuss your project further, give me a buzz and ill go over everything with you, easier to talk then type
Old Jul 2, 2008 | 10:08 PM
nj02vette's Avatar
nj02vette
Good to know that
Thanks.
To whould this work in a 2002 a4
