torque tube guts
Old Jul 2, 2008 | 05:41 PM
slow ride's Avatar
slow ride
Default torque tube guts
Has anyone purchased the guts for the torque tube? I'm talking about everything inside of the tube. Input shaft, two bearings, two rubber couplers, etc, etc. I might need the tube guts if my clutch/flywheel are not found to be the problem (minor vibration). Whats the best place to buy it? I'd like to get the the current stuff looked at, but it's not easy to find someone to service this type of driveshaft. I've chacked the couplings and bearings which are good. Either the input shaft or driveshaft part of the torque tube are bad (if it's not the clutch).
Old Jul 2, 2008 | 05:54 PM
jbauch357's Avatar
jbauch357
Got the bearings from GM (3 total) and the couplers from DRM (you can also order them from Bovarian Motor Works).
The shop that did my clutch swap also did the driveline rebuild, said it was a real PITA and he had to buy a special pair of snap ring plyers to get the job done...
Old Jul 2, 2008 | 11:09 PM
slow ride's Avatar
slow ride
I've had all the stuff out to look at it and yes the big snap ring is a PITA. The only parts suspect to me are the input shaft and actual aluminum shaft. I don't think you can buy those two parts seperate (someone let me know if I'm wrong). Anybody else have experiance?
Old Jul 2, 2008 | 11:52 PM
KCvetteowner's Avatar
KCvetteowner
That is what I have been told. Now you can purchase a carbon fiber shaft and then run two billet bushings on each end for about $1500. Otherwise you can run one rubber bushing and one billet with the stock aluminum shaft.
Old Jul 3, 2008 | 12:18 AM
nickolbag's Avatar
nickolbag
When I bent my driveshaft I got a used z06 tube here on the forum for $300.
Old Jul 3, 2008 | 07:09 AM
slow ride's Avatar
slow ride
Well I thought about a used complete unit (tube and shell), but they are not always available. They might need the bushings replaced in them also.
Old Jul 3, 2008 | 10:02 AM
nickolbag's Avatar
nickolbag
True, it is hit or miss. Worth a try at least.
Old Jul 3, 2008 | 03:23 PM
ragtopws6's Avatar
ragtopws6
I used a BMW rubber bushing for the front and a billet aluminum for the rear. The parts cost me $200 for both shipped. You really don't need to upgrade to a Z06 tube (they do have bigger diameter shaft). Fartpipe runs 11.02 @ 126 with this same setup. Click on this link, I did the bushing while I was replacing my trans/rear.
http://forums.corvetteforum.com/show....php?t=2053182
Old Jul 3, 2008 | 03:37 PM
nickolbag's Avatar
nickolbag
BMW parts...maybe thats why Fartipe can't run 10s.
Old Jul 3, 2008 | 04:19 PM
vrybad's Avatar
vrybad
You can get the input shaft at the dealer, but is very pricey at about $500.
I don't know the prices on the other parts.
Old Jul 3, 2008 | 04:59 PM
slow ride's Avatar
slow ride
Again, I'm not sure if I'll need this or not, but just trying to line up parts if need be. I have a 02' zo6 so I already have the better torque tube. My couplings are both fine and I plan to stay with the rubber style ones. I'm just not sure if I tweaked the input shaft (which should eat up the pilot bearing, but mine is fine) or have a slight tweak in the shaft.
My problems might just be in the clutch, but I just want to find out what the best place to buy the parts (not the couplings).
Old Jul 3, 2008 | 05:31 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
no Al or rubber 'bushings', there are bearings and couplers/ings in there
Old Jul 3, 2008 | 05:44 PM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
A complete prop shaft is shown in the parts manual, which includes new couplers, bearings, etc... Obviously there are several part numbers. If I remember correctly the one for my 02 Z listed for $550 on Gene's website.
FWIW, According to the manual you should not separate the input shaft, propeller shaft, couplings, or bearing housing assembly, unless required. These components are balanced as an assembly. Disassembly and improper assembly of the components may cause vehicle driveline vibration.
If the input shaft, couplings, propeller shaft, or bearing housing assembly must be separated, the components must be marked prior to disassembly. During assembly, the components must be returned to their original position and location.
Old Jul 23, 2008 | 10:31 PM
slow ride's Avatar
slow ride
Well everything is out again and after looking at some things I have a question. Has anyone spun the torque tube and watched the input shaft spin on the other end? Did you see any runout (even just a tiny bit)? The couplings are fine(not origional) and the shaft seems stright to the eye, but the input shaft has a tiny bit of runout. I don't have another tube here to compare it to though.
I ended up balancing the clutch and it was 20 grams out. I'm 95% sure this was the cause of my vibration, but I'm not sure about the input shaft on the torque tube. Can anyone spin a known good tube and tell me what you see
Only reason I'm nervous about the input shaft is I found a bad pilot bearing, but that could have been caused during install last time. The bearing wasn't causing any problems and the old bearing before this one was fine, but I replaced it when switching clutches. I should just replace the whole damn thing, but I don't like to wast money on something I might not need. Help a brother out
Old Jul 24, 2008 | 02:28 AM
vettekidc5's Avatar
vettekidc5
I put new coupler bushings in mine when I did my clutch. I spun the shaft just like you did and the imput shaft spun out of round too.. I was paranoid this woild be a vibration issue..
I took the tube back apart and looked at it again thinking I didnt do something right, but sure enough it was fine.. So i said screw it and put it in and it hasnt had a problem..
Keep in mind the shaft is bolted to the ruber bushing, and it rests on the pilot bearing. I held it real firm where the pilot bearing would hold it and I didnt notice any real runout at that time. The pilot bearing plays a key role in supporting that shaft, and eliminating the out of round.
You should be fine
Old Jul 24, 2008 | 05:04 PM
slow ride's Avatar
slow ride
Thanks for the response. After speaking to RPM and a friend of mine I'm confident that most torque tube input shafts will look like they have just a touch of runout when spun by hand. Without the pilot bearing to support the shaft it's hard to keep the input shaft centered since it is bolted to a piece of rubber on one end as you said.
Old Jul 28, 2008 | 10:25 AM
slow ride's Avatar
slow ride
Anybody else notice a small amount of input shaft runout?
Old Jul 28, 2008 | 10:40 AM
atsugidad's Avatar
atsugidad
Had to replace complete Torque Tube assy a few years ago om my 02 A4 Coupe. Had a vibe at 2000 RPM. Turned out that the Front Bearing race had spun in the housing. No fix, only replacement. Complete unit was $2300 from GM. I thought they should have repaced the tube and reused the shaft - replacing bearings and coupler.
When the dealer found the problem, they discovered the clamp coupling at the flywheel was loose - maybe 40# instead of 95# or so. Car had 35000 miles on it, but had the Tranny replaced for defect under warranty at 4000 by another dealer before I got the car.
Phil
Old Aug 4, 2008 | 09:11 PM
slow ride's Avatar
slow ride
My runout was ok. After zeroing out the clutch ***. the car is smooth again. No problems with the torque tube.
To torque tube guts
