Looking for a cure for a notchy 6 spd
Old Dec 26, 2001 | 02:37 AM
MOOVOVR's Avatar
MOOVOVR
Default Looking for a cure for a notchy 6 spd
I installed the B&M Ripper some time ago and I am glad. I am pleased with the reduced throw, however, the shifter feels a little "notchy". Has anyone experience such a feel? Would changing the fluid to synthetic make a difference?
Old Dec 26, 2001 | 09:05 AM
Jim 47's Avatar
Jim 47
Default Re: Looking for a cure for a notchy 6 spd (MOOVOVR)
Replace the transmission lube with Redline MTF. It will remove the notchyness. It is RED just like the Dexron ATF in your transmission from the factory, so visually it looks the same as the factory ATF.
Old Dec 26, 2001 | 10:55 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
You may also want to change the clutch fluid to synthetic - it helped me.
-Jeremy
To Looking for a cure for a notchy 6 spd
