Hurst Roll Controller (Line Lock)
Old Dec 26, 2001 | 03:59 PM
robiferretti's Avatar
robiferretti
Default Re: Hurst Roll Controller (dsk888)
yeah i am ordering that too soon :yesnod:
Old Dec 26, 2001 | 04:10 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: Hurst Roll Controller (robiferretti)
The trick to this installatation is combining the metric ends with the SAE lines. I took the factory line that is marked as the "MC1" line on the ABS unit, cut the line to retain the stock metric ends. I used a standard line and drill out the metric ends to fit over them. Make sure that you do the new double flare to the ends that go back to the ABS unit and towards the master cylinder preportioning valve. Other then that its a straight up installation.
You also should be able to bleed it at the ABS unit and not at the calipers. This modification is a must for drag racing!!
