remove a4?
Old Jul 7, 2008 | 01:16 PM
n_brio's Avatar
n_brio
Default remove a4?
how does i loosen the a4 gearstick?? i have remove the 4 10mm bolt but how do i do now?
i only have that part left now
i hope some one can help me
Old Jul 7, 2008 | 01:40 PM
MattB's Avatar
MattB
Not sure what you are trying to do, but there are two cables on the A4 shifter. One goes to the ignition switch and the other to the transmission. I'm pretty sure both have to be unhooked before the shifter will come out.
Old Jul 7, 2008 | 03:22 PM
n_brio's Avatar
n_brio
yes i have done that but how do i pick apart the wire from the gear stick to gearbox??
Old Jul 7, 2008 | 07:21 PM
4DRUSH's Avatar
4DRUSH
If you're talking about the electrical conection on the driver's side of the trans. Don't try to discount the conector (they weld them selves together) , just remove the whole plate the conector is attached (2- 10mm bolts) and slide it over the shaft.
To remove a4?
