Hvac
Old Jul 7, 2008 | 05:17 PM
mike10626's Avatar
mike10626
Default Hvac
It's on a 1999 Dual Climate; I can not shut it off by using the off button, and can not change the temp. when I turn the **** it showes the outside temp. Everything else works. I pulled #27 fuse. That did not cure it. Can anyone help?
Old Jul 7, 2008 | 07:43 PM
BlackZ06's Avatar
BlackZ06
When you remove Fuse 27 you must wait AT LEAST 60 seconds before re-installing the fuse .... it takes time for the "memory" in the HVAC controller to clear.
Second, check and see if any DTC are set for the HVAC controller. Post the DTC and someon can help you diagnose the problem.
Old Jul 7, 2008 | 11:51 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
It sounds toasted, but I'm curious for the outcome.
Old Jul 8, 2008 | 01:42 AM
Goody's Avatar
Goody
Write down your codes first but then undo the battery and let it sit overnight. That way if the actuators are out of whack this will realign them.
Likely the HVAC module is done, but first the codes and the manual for a bit of reading/troubleshooting....saves money on parts.
Old Jul 8, 2008 | 05:08 PM
mike10626's Avatar
mike10626
I work so much it takes time for me to get back . There are no codes in any area. It is stuck on 73, when its in auto. But you can not change anything when in auto. Take it out of auto everything works but I can not change temp. But in any mode you can not shut it off. I had #27 out 3 or 3 hours but nothing.
Old Jul 8, 2008 | 05:59 PM
patton's Avatar
patton
St. Jude Donor '09
do a search,i think there are 2 fuses to pull
Old Jul 8, 2008 | 06:29 PM
BlackZ06's Avatar
BlackZ06
If you have no codes, and pulling fuse 27 (or disconnecting the battery) has no effect, then the HVAC head unit sounds like it is FUBAR.
For your 1999 the dual climate control unit is GM part number 16254311 and list price is $500.78 (I never understand GM pricing ..... why not $500.99 ... or just screw it and call it $500.00 ????)
Check supporting parts vendors such as ....
http://www.gmpartsdirect.com
or
http://www.gmpartshouse.com
as they will have better prices.
Old Jul 9, 2008 | 05:11 PM
mike10626's Avatar
mike10626
I have done a search and nothing comes up. Also I E-Mailed GM Parts and no reply yet. If you need a remote that's where to go GM Parts he is good.
Old Jul 15, 2008 | 02:38 AM
tstar's Avatar
tstar
Mike I've seen em on Ebay for alot less with warrantees... If you get a new one keep me in mind for your old one as I can use it for parts!
Tim
To Hvac
