EBCM & fuse question
Old Jul 8, 2008 | 04:02 PM
50yrzo6's Avatar
50yrzo6
Default EBCM & fuse question
I was checking out ABSfixer.com as I'm pretty sure my EBCM is out. (fuses are good and grounds look good) I noticed on their site they suggested pulling the big fuse that controls the module. Does anyone on here recommend that? The way I understand it the pump will run all the time if you don't pull the fuse since the EBCM is not controlling it. I believe it is fuse #52 or 53 isn't it? Does that fuse protect anything else? Thanks.
