Clutch issue...
Old Jul 8, 2008 | 06:55 PM
cortex's Avatar
cortex
Default Clutch issue...
Twice now over the past couple days I've had to "pump" the clutch 4-5 times to get it to return to its proper position relative to the floor. It started maybe two or three inches off the floor.
Fluid is full. Both times so far have been warm starts.
Could this be an internal leak involving the master cylinder? Anything else come to mind?
110,000 miles on all original parts relative to the clutch. Thanks!
Old Jul 8, 2008 | 06:59 PM
CleteZ16's Avatar
CleteZ16
St. Jude Donor '09
What color is the fluid? If it's black, do the turkey-baster thing.
Old Jul 8, 2008 | 07:08 PM
cortex's Avatar
cortex
Like it just came out of the bottle.
Old Jul 8, 2008 | 07:46 PM
k0ts's Avatar
k0ts
I have an AC Delco master (brand new)... AC#18M882, GM#88928097
I bought it to do my clutch and ended up buying a package of everything.
and your problem does sound like the master..
Old Jul 8, 2008 | 07:48 PM
Goody's Avatar
Goody
Do a search of the "Ranger" method and other clutch searches as there are far too many strings of info available.
110K means you may need to start replacing some worn out parts. Likely culprit is the clutch slave cylinder. I wish I could have gotten that many miles out of mine....on the 2nd already and want it gone.
To Clutch issue...
