Passenger door lock doesn’t work
Old Jul 9, 2008 | 02:40 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default Passenger door lock doesn’t work
Like the title says, the lock will not lock when I push the lock button. Driver’s side is fine. Any suggestions as to where I should look first?
Thanks,
Clayton from Las Vegas
Old Jul 9, 2008 | 03:44 AM
BlackZ06's Avatar
BlackZ06
If you mean that it doesn't lock when you push the drivers side lock button .... see this thread ......
http://forums.corvetteforum.com/show....php?t=1606865
If you mean that pushing the manual lock lever on the passenger doesn't work, post back, you have a mechanical problem.
Old Jul 9, 2008 | 05:54 PM
NeoZ06's Avatar
NeoZ06
door control module sounds like its faulty, that is, if the actual manual lock button is not jammed or something...
http://www.ronjpics.com/Corvettestuff.htm#DCM
To Passenger door lock doesn’t work
