I have done a search and have read several threads on the TPMS and had a few questions since it seem so confusing.
I have a 1999 and the DIC displays the message Service Tire Pressure Monitor System. I get a reading on all but the right rear. I realize that the battery may be low but I am hesitant to do a relearn in case the monitors do not respond.
Are the C5 like the C6 where you are not able to go into competition mode if the TPMS has an error. I have just been hitting reset on the DIC to get rid of the message. I don't mind having this annoyance. Is that all it is on the C5 or will there be other problems to come. Any help would be greatly appreciated. The more I read, the more confused I get.
Yes, batteries will give out. Also the centrifugal micro switch that activates it can stick and cause a failure. About the only thing you can do is replace it. There is a place that will repair them, but their website is infected with spyware really bad.
I’m not sure but when I put on aftermarket wheels the light was on for a while. After disconnecting the battery the light never came on again. I don’t have sensors in the wheels anymore. Thy are expensive to replace and not worth the aggravation in my opinion. I don’t run run flats on my car anyway.
Just a thought here is if you aren't running runflat tires, then I personally would think the TPMS is even more important in case you pick up a nail.
Don't know what "light" you are talking about .... you will get a SERVICE TPMS message on the DIC at various times.
Driving without the sensors with "standard" tires means that when you get a flat, the first thing you will know is when the rim is down on the road. Most Corvette rims (wheels) cost far more than a set of TPMS. Your choice .... ruin a wheel or put in new sensors ...... also realize that the Z06 cars, which don't have sensors, came with fix-a-flat kits and inflators .... you'll have no choice with a flat than to call for a tow truck ..... with the sensors many people find they can "limp" to a service location before the tire is completely flat because they are warned of low pressure long before the tire is completely flat.
