C5 Gremlin's
Old Jul 9, 2008 | 04:53 PM
GS023's Avatar
GS023
Default C5 Gremlin's
Still trying to resolve my battery drain issue on my 02. I have narrowed it down to the illumination for the DIC and HUD control buttons. They stay illuminated constantly. I have cleaned all the grounds under the hood and on both kick panels, no luck. Anyone ever run across this or have any suggestions?
Old Jul 10, 2008 | 08:16 PM
Brad Ratledge's Avatar
Brad Ratledge
4th Gear
Just got mine fixed. It was doing the same as yours. Found a burnt spot in the circuit board in the instrument cluster. This fixed to DIC and HUD lights but I removed fuses and tracked the rest of the battery drain to the glove box light. Cost $650 to get a rebuilt cluster at the Chevy dealer. Quite a job to replace. Hope this helps.
Old Jul 10, 2008 | 10:54 PM
GS023's Avatar
GS023
Thanks, was the burned spot easy to see once removed?
Old Jul 11, 2008 | 07:56 PM
Brad Ratledge
4th Gear
Not very easy to see. I wish I had taken pics but did not think of it at the time. I chased mine around for about 3 months before tearing into the dash. Listening to most people's advice I thought it was the BCM but I could not confirm this with any type of test. Something that I did not mention before was that during this time I replaced all four tire pressure sensors and the new ones would not program. I have service manuals that I will loan you if you are local to Winston Salem NC. Thanks, Brad
Old Jul 12, 2008 | 07:17 AM
GS023's Avatar
GS023
I do have a set of factory service manuals. I talked to my Chevy parts guy and he said that I needed the part number from the back of the IPC and the last 8 of the VIN to order a reman unit. Will probably tear in to it soon. You were able to see the bad spot in the circuit?
Thanks again for the advice.
To C5 Gremlin's
