Passenger door window won't go down !!!
Old Jul 9, 2008 | 06:12 PM
Sinister-one's Avatar
Sinister-one
Default Passenger door window won't go down !!!
Like the title says..... My passenger door window quit on me. Any ideas as to what this is going to cost me to fix ?
Old Jul 9, 2008 | 07:20 PM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
Open the door and look between the door jam. You'll see a black accordion loom....wiggle this around and try your window switch again.
Old Jul 9, 2008 | 08:50 PM
Goody's Avatar
Goody
Post any codes you have in the DIC.
Old Jul 10, 2008 | 12:46 AM
Sinister-one
There's no electrical issues. I press the window switch and you can hear the clicking from the motor within the door.
No codes show up in the DIC.
Old Jul 10, 2008 | 08:11 AM
slvr76's Avatar
slvr76
My passenger side window did the exact same thing last year. I looked on the forum and one thread said to hit the area right behind the speaker with your fist. I tried it and it worked. Apparently the electric motor can sometimes stick, especially if you don't use it that often. You have to hit that section of the door panel pretty hard, but its certainly worth a try
Old Jul 10, 2008 | 08:32 AM
AFTRBRNR's Avatar
AFTRBRNR
Yup; same thing, same solution.
Old Jul 10, 2008 | 08:43 AM
at88mph's Avatar
at88mph
Hey, I didn't say the solution made sense Just give it a try
Old Jul 10, 2008 | 01:40 PM
Bluefire's Avatar
Bluefire
I fixed mine 1.5 years ago with "percussive maintenance". Turn the key on, open the door, hold down the window button. Now, make a fist and beat the snot out of the inside, lower center of the door. Mine worked after about the 8th hit. Good Luck.
Old Jul 10, 2008 | 02:04 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
And after you get it working again make sure you cycle the window every day to keep it from happening again.
Old Jul 10, 2008 | 02:18 PM
AFTRBRNR's Avatar
AFTRBRNR
Classic German engineering.
Old Jul 10, 2008 | 06:26 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
So thats why we have the smilie!!
Old Jul 10, 2008 | 07:19 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
some one hung the handle "Fonzi method"
It works!
Old Jul 10, 2008 | 07:54 PM
TEXHAWK0's Avatar
TEXHAWK0
Beating on it and cycling it might make it work for awhile, but once they mess up, you need to replace the whole regulator assembly to get a permanent fix.
Mine worked off and on, and finally quit completely.
I replace both regulator assemblies and have not had another problem.
The assembly will cost you $300 to $400 from a dealer, but there are internet sites that will sell for less than $200.
You can easily replace it yourself and save several hundred dollars labor.
Old Jul 10, 2008 | 08:59 PM
Choreo's Avatar
Choreo
Same experience here. Beat on it - worked for about 3 weeks. Beat on it again - worked for about 2 weeks. Third time it BEAT ME. Replaced both window regulators under warranty.
Old Jul 10, 2008 | 09:24 PM
Sinister-one
PM sent your way.
Old Jul 11, 2008 | 04:02 PM
Bluefire's Avatar
Bluefire
It works!
That was me. :o
Old Jul 11, 2008 | 04:04 PM
Bluefire's Avatar
Bluefire
I beat mine into submission once ~1.5 years ago. It has worked ever since. I do make sure I use the passenger window more often now.
To Passenger door window won't go down !!!
