2000 coupe removable top coating peel????
Old Jul 14, 2008 | 03:12 PM
Sully1882's Avatar
Sully1882
Default 2000 coupe removable top coating peel????
On my 2000 the lexan targa top on the passenger's side is looking like it is peeling off... leaving it dull and looks like hell!!!! anyone else deal with this? if so what can be done? anything simple?
Sully
Old Jul 14, 2008 | 04:14 PM
jrose7004's Avatar
jrose7004
They all do it sooner or later if they stay outside. I had mine painted body color on my 98 or you can have it redone at www.astrotops.com.
I have seen some post on here about rubbing it out so try a forum search.
Old Jul 25, 2008 | 11:26 AM
Sully1882's Avatar
Sully1882
no kidding... they all will peel? Well crap... that just sucks!!! man i just hate the way it is starting to look... i guess it's time to pull out the fiberglass one..
thanks,
sully
Old Jul 25, 2008 | 12:33 PM
Oldvetter's Avatar
Oldvetter
It helps to apply diaelectric grease to the area. The Lexan top has a silicone coating which peals after long sun exposure.
Some people have had success sanding and re-clear coating it.
If you paint it a color, clean well and use an ahesion promoter.
Old Jul 25, 2008 | 03:21 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Wet sand it. Polish with fine grit paste than finer grit McGuires has it.
Clean with Amonia and water.
Tape it off and clear coat it. Two coats is good. let it set a ouple of days.
Sand it gently with superfine sandpaper (wet) wipe it down. Polish with regular polish usong a side buffer. Take your time. I used McGuires.
Did two so war and they look great. Now that I've done theirs it's time to do mine.
Old Jul 25, 2008 | 04:25 PM
hotmerc's Avatar
hotmerc
I sanded & reclearcoated mine 2 yrs ago & it still looks like the day I did it. Also it now is a painted surface & can be treated just like the rest of your painted surfaces.
Old Jul 25, 2008 | 04:39 PM
c5streak's Avatar
c5streak
Here's one member's process.
http://forums.corvetteforum.com/show...ht=re-clearing
To 2000 coupe removable top coating peel????
