ABS Code
Old Jul 14, 2008 | 10:39 PM
delta doug's Avatar
delta doug
Default ABS Code
My 99 Coupe w/auto, will throw an ABS/Traction Control code,
usually when hitting a significant bump. It does not go into
reduced engine power, but the dash lights stay on until ignition
is turned off, then it clears.
Anyone know if when hitting the bump, it is reacting as it
should, or could it be a loose ground wire?
Old Jul 14, 2008 | 11:33 PM
motogib1's Avatar
motogib1
Step 1, check your codes. Turn the engine off, then turn the key to on without cranking engine. Press and hold the options button. With the options button held in, press the fuel button 4 times within 10 seconds. You can then manually check your codes. You can do a search and get in depth info on checking codes from your dash readout. Once you have the codes, post them here and someone will be able to assist you.
Old Jul 15, 2008 | 10:20 AM
Rollin's Avatar
Rollin
Be ready the codes roll by fairly fast and it can be hard to write them all down.
To ABS Code
