low oil warning
Old Jul 15, 2008 | 10:31 AM
02gt350's Avatar
02gt350
Default low oil warning
what plug is it that reads this? the small blue one behind the starter?
Old Jul 15, 2008 | 10:40 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Old Jul 15, 2008 | 11:07 AM
02gt350's Avatar
02gt350
hum.........but its plugged in
Old Jul 15, 2008 | 11:11 AM
BlackZ06's Avatar
BlackZ06
What's the question .... why wouldn't a sensor be "plugged in" .... ????
Old Jul 15, 2008 | 11:20 AM
02gt350's Avatar
02gt350
why am i getting the code if it IS plugged in
Old Jul 15, 2008 | 11:47 AM
BlackZ06's Avatar
BlackZ06
1) You are one quart (or more) below the FULL level (check your dipstick)
2) If the oil level is correct then the sensor has failed.
GM part number 12603782
torque spec for installation is 115 INCH/lbs
Old Jul 15, 2008 | 05:16 PM
02gt350's Avatar
02gt350
hum....this is showing 20 minutes after the new motor has been put in....just put in 7 quarts, so I know its not low
Old Jul 15, 2008 | 05:25 PM
BlackZ06's Avatar
BlackZ06
Hmmmm .... bad sensor or bad wiring ... the sensor is $22.42 at GM list ... and you most likely know a forum vendor that will sell it cheaper.
Only other possibility ..... in a cold engine it takes a while for the oil to drain down into the pan ... is the dipstick showing the correct level ???
Old Jul 15, 2008 | 05:46 PM
MattB's Avatar
MattB
If you have a good Oil PSI reading, then it could be wiring. I think the circut is always powered, and if the oil level gets low it breaks the circut and you get the low oil level indication. So, a break in the wiring will get you the message.
Pretty easy to mis-route the wire and burn it or damage it. Its pretty cramped down there...
Other than that, I'm sure it goes without saying but, double check the oil, if its a new engine there are all sorts of ways to loose oil. And make sure you have good oil psi reading before running it long.
Old Jul 15, 2008 | 08:08 PM
aleadfoot's Avatar
aleadfoot
Could be a bubble that will pass. do nothing if the oil level is good the burp will clear and the warning disappear. patience
Old Jul 16, 2008 | 12:23 AM
02gt350's Avatar
02gt350
yup, seem to go away
To low oil warning
