a/c idler pulley stuck
Old Jul 15, 2008 | 11:09 PM
gator79's Avatar
gator79
Default a/c idler pulley stuck
is there a trick to getting it off? I have the water pump out of the way already but the pulley does not want to come off the shaft. soaked it in penetrating oil and will try again tomorrow, the car has 150K on it and this is the original a/c idler
Old Jul 16, 2008 | 09:38 AM
jedblanks's Avatar
jedblanks
IIRC my AC idler had a bolt going through it, into the block. Not a shaft....
Old Jul 16, 2008 | 01:32 PM
gator79's Avatar
gator79
yes there is a bolt thru it but the inside of the idler pulley bearing slips onto a shaft/boss that is aluminum and is part of the a/c mounting bracket. the inner part of the bearing is stuck to the aluminum shaft/boss. I may just get a small gear puller to get it off.
Old Sep 25, 2020 | 05:41 PM
johnson-rod's Avatar
johnson-rod
That's what is so great about this forum. The thread is from 2008 and it had the exact information that I needed today in 2020. None of the pictures or diagrams or the FM goes into this detail.
To a/c idler pulley stuck
