wire from ignition
Old Jul 16, 2008 | 01:23 AM
MIBagentR's Avatar
MIBagentR
Default wire from ignition
Hi Guys, I have another question for all you mech guru's
When I was under my dash putting in my CLB, I noticed that there was a wire coming out of the ignition. The wire that came out of the ignition had a connector on the end but was disconnected. When I tracked down the other connector/wire I noticed that it had been spliced together.
Any ideas why someone would do this?
I am not getting any errors on my DTC.
Old Jul 16, 2008 | 03:37 PM
byronhunter's Avatar
byronhunter
Default Vats
Wire from Ign lock reads VATS pellet in key. Can be bypased with correct value resistor.
