Oil
Old Jul 16, 2008 | 11:38 PM
hgoodwiniii's Avatar
hgoodwiniii
Default Oil
I get a low oil light on my 2001 convertable with standard transmission every ~800 - 1000 miles. The light goes out after I add a quart or 1.5 quarts. Does anyone else experience this?
Old Jul 16, 2008 | 11:43 PM
BlackZ06's Avatar
BlackZ06
Any engine will use some oil, but a quart every 800 to 1,000 miles should be looked into. You could have an oil leak from a bad gasket, or you could be burning oil because it is getting past the piston rings or valve guides. Have the engine inspected.
Old Jul 17, 2008 | 08:25 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Some 2001 Corvettes, especially those equipped with manual transmissions, had oil consumption issues caused by low tension piston rings.
After verifying actual oil consumption, GM dealers will replace the rings on engines that consume more than 1 qt. of oil per 1000 miles.
In your case, a qt. of oil in 800 - 1000 miles is close to the Gm "acceptable range". I would just leave it alone, and get in the habit of checking the oil level more frequently.
Old Jul 17, 2008 | 10:12 AM
jrose7004's Avatar
jrose7004
Some 01 had oil burning issues. Do a search on it, there's been lots of post about it.
To Oil
