Why does my exhaust pop/Backfire?????
Old Jul 17, 2008 | 02:31 AM
c4vetteontop's Avatar
c4vetteontop
Default Why does my exhaust pop/Backfire?????
On my 98 with headers/no cats with x and Borla stingers. When ever the rpm drops it sometimes pops/backfires. (When it drops at a high rpm) Ive been told that there is about a 2 feet flame that shoots from my tips. I dont mind it or anything but im just wondering why this is and if it's causing any harm to my vette.
Old Jul 17, 2008 | 03:53 AM
Gicantor's Avatar
Gicantor
Check your exhaust for cracked welds etc. Same thing happened to me. Had a crack in the header collector. It sucks in fresh air and ignites unburnt fuel.
Old Jul 17, 2008 | 07:17 AM
AJay's Avatar
AJay
Get a dyno tune. It will eliminate the rich mixture in the exhaust and stop the popping and backfiring, add a few extra RWHP and probably even increase your mileage
Old Jul 17, 2008 | 08:27 AM
Robls6's Avatar
Robls6
I like when my car does that.
Old Jul 17, 2008 | 07:19 PM
mxw1's Avatar
mxw1
They all do that when letting off the throttle below about 2500 RPM. With your stock exhaust, it's so quiet, that you can't hear it.
Above 2500 RPM, when you let off the throttle, you don't get backfires because the engine computer shuts off all fuel, until the RPMs approach the idle speed, then fuel is added again.
Now you can hear it with your louder exhaust system.
Old Jul 17, 2008 | 09:29 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Delete your AIR system, you'll never hear it again.
And yes, shooting flames running catless is fairly common.
Old Jul 18, 2008 | 11:34 AM
David426's Avatar
David426
Ever been to a NASCAR race?? Obviously not,, When the cars are approaching a turn coming off of a high speed straight they have to let off the throttle.. Lots of backfiring and a firework show out the pipes. I like it
Old Jul 18, 2008 | 01:37 PM
RyanR0101's Avatar
RyanR0101
A Corsa rep told me the factory H pipe is partly responsible for this. An X pipe will cure at least some of it. I'm not that concerned about it.
Old Jul 22, 2008 | 08:48 PM
cruzc5frc's Avatar
cruzc5frc
I call BS on this I have ARH 1-3/4 w/ offroad X and no cats.. still has the popping.. considering removing AIR
Old Jul 23, 2008 | 09:57 AM
jedblanks's Avatar
jedblanks
I think an X-pipe might help on a stock setup, but most header setups already have an x-pipe.
Old Jul 23, 2008 | 02:07 PM
bgreen83's Avatar
bgreen83
I get popping when I let off the throttle from high RPM's. Isn't it just because fuel gets into the pipes and heats up and ignites in the pipes creating the popping noise?
Old Jul 23, 2008 | 02:11 PM
falcon5619's Avatar
falcon5619
I have LG LTs no cats and X-pipe and it still does pops. I like all the rumbling. When I don't want all the noise I drive the Lexus.
Old Jul 23, 2008 | 03:05 PM
Celura's Avatar
Celura
St. Jude Donor '08
In a nutshell, isn't it caused by a lack of backpressure?
Old Jul 23, 2008 | 03:12 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
No.
Old Jul 23, 2008 | 03:17 PM
Celura's Avatar
Celura
St. Jude Donor '08
Originally Posted by Y2Kvert4me
No.
Ah well, that's what I was always told. Guess I learned something new today.
Old Jul 23, 2008 | 03:33 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Mine popped like crazy and occasionally shot flames for many years. (LT's no cats, X-pipe)
Since deleting the AIR system 2 years ago, it's never done it even once.
I can coast down from 6k rpm, and it's just smoooth.
And, running a cam with ~20* overlap, trust me there's no shortage of unburnt fuel passing through those pipes.
Nothing changed with my exhaust system during that transition, it's remained the same for the past 6 years, so the exhaust is not the culprit.
I've seen others say it, and based on my experience, I agree, it is the AIR system that causes the popping phenomenon.
Old Jul 23, 2008 | 05:12 PM
Celura's Avatar
Celura
St. Jude Donor '08
Wow, that's really interesting! I had no idea.
How does one go about the AIR delete mod? Is there a DIY thread somewhere?
To Why does my exhaust pop/Backfire?????
Old May 26, 2017 | 02:29 AM
2L8LUZ's Avatar
2L8LUZ
Can someone please explain the "Air System" to me?? CAI?
thx
Old May 26, 2017 | 09:30 AM
huesmann's Avatar
huesmann
It's an emission control that injects fresh air into the exhaust to lower tailpipe emissions after startup.
Old May 26, 2017 | 09:37 AM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
Mine had a silent exhaust leak on one of the longtubes.
When I replaced the clutch they re and re the headers with new gaskets and no more popping....
