MAF/IAT Harness Adapter
Old Jul 17, 2008 | 10:48 AM
kromberg's Avatar
kromberg
Default MAF/IAT Harness Adapter
Does anyone know where I can find an adpater that will split a 5-pin connector for the MAF and IAT harness into separate connectors for a MAF and IAT sensor?
Keith
Old Jul 17, 2008 | 11:53 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Don't know. but if you can't find it.. here's the wiring:
Delphi 76mm 3-pin MAF is used on '98-'02 F-Bodies and older
Corvettes.
Delphi 5-Pin MAF
Connector Pins, left to right, looking into inlet
(Left)
1 IAT output, to IAT harness, TAN (tan), to PCM C2 Pin 25
2 IAT reference, to IAT harness, PPL (purple), to PCM C1 Pin 57
3 MAF ground, to MAF harness, BLK (black) to main ground dist.
4 MAF power (IGN), to MAF harness, PNK (pink) to ENG SEN fuse
5 MAF output, to MAF harness, YEL (yellow) to PCM C2 Pin 31
(Right)
'98-'02 3-pin MAF
(Left)
1 MAF output, to MAF harness, YEL (yellow) to PCM C2 Pin 31
2 MAF ground, to MAF harness, BLK (black) to main ground dist.
3 MAF power (IGN), to MAF harness, PNK (pink) to ENG SEN fuse
(Right)
Old Jul 17, 2008 | 11:31 PM
Rob Petyo's Avatar
Rob Petyo
"caspers electronics" might have it...Google is your friend
Old Jul 18, 2008 | 11:54 AM
1999vettrroo's Avatar
1999vettrroo
Default Here ya go
www.zzperformance.com
1xMAF adapter with IAT plug MafAdaptIAT
Sub-Total: $19.99
Tax: $0.00
U.S.P.S(PRIORITY)(1 X 0.50 lbs) (Shipping): $7.80
Total: $27.79
To MAF/IAT Harness Adapter
