The GM service manual says to "stroke the brake pedal while pressure bleeding". The techs I've talked are puzzled by why that's needed. If so, when exactly is the right time to stroke the pedal?
A. pump pedal, release pedal, open bleeder...
or
B. pump pedal, open bleeder...
Don't forget we are pressure bleeding at 20-25psi.
or
If you're using something like a Motive pressure bleeder then just leave the pedal alone. It'll bleed fine.
My Service Manual has two procedures one is manual and the other is pressure. The manual one has somebody pressing the brake pedal but the pressure procedure does not mention touching the brake pedal.
If you have two people, I still prefer the manual method.
I think you can build more pressure using the pedal than you can with a pressure bleeder where the reservoir is involved.
