Quick question about exhaust/header install
thanks
If you go w/ headers, you'll want long tubes. They will give you more than an increase in volume, you'll make more power in the process but it won't be as loud as if you just got some Bullets or another comparable cat back system especially if you retain your stock cat back w/ the LTs.
There are no LT headers that I know of that will bolt up to to the stock H pipe which is why most LT headers are sold as "systems" which include a x-pipe and cats (or off-road set-up sans the cats). There are few LT systems within your budget (new), at least not the premier systems such as LG, ARH, Kooks, etc... which are easily $1k+
One other thing, to maximize the LT's you'll want or need a tune which will run you another $400-$500.
So..... it looks like the cat-back will be your best bet for now! Good luck.
