drive belt problems
Old Jul 20, 2008 | 09:42 AM
tonylittell's Avatar
tonylittell
Default drive belt problems
I have a 97 coupe and i saw the belts were starting to crack so i replaced them. now i find that the main drive belt wants to keep jumping backwards towards the engine about 2 grooves off the pulley. i have re-installed the belt several times and even tried installing it the opposite way. but the same thing happens. it walks up the back side of the crank pulley towards the a/c belt about 2 grooves and stays there but sits on all the other pullies just rite.... anyone got any ideas as to what the problem may be?
Old Jul 20, 2008 | 09:57 AM
wildbadbill's Avatar
wildbadbill
do you have the proper tension on it? Is the routing correct? With the proper tension there is no way the belt can lift up enough to jump the grooves IMHO
Old Jul 20, 2008 | 11:24 AM
tonylittell
How can you have anything but the right tension on it. its a self adjusting tensioner. its not lifting from lack of tension its almost like something is putting enough pressure on it to push it that way and then it juts stays there. cant figure it out
Old Jul 20, 2008 | 11:26 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Is the harmonic balancer still on all the way? One of the pulley's isn't lined up any more therefore you need to figure out which and fix.
Old Jul 20, 2008 | 11:33 AM
tonylittell
looking at it makse me think the idler pulley under the alternator may have moved in towards the block some how and is making the belt walk over the ridge on the crank pulley(ballancer)
maybe the balancer isnt on all the way i will have to check it the next chance i have
Old Jul 20, 2008 | 11:56 AM
jrprich's Avatar
jrprich
I thought I read a Gene Cully post that the C6 pulleys fit the C5 and have a higher edge lip to prevent such issues
Old Jul 20, 2008 | 12:02 PM
tonylittell
i dont want to bandaid an underlying problem. i would rather fix the problem and then possibly use those types of pullies
Old Jul 20, 2008 | 12:10 PM
byronhunter's Avatar
byronhunter
Default pulley
Your crankshaft pulley and/or ballancer is headed toward the power steering rack, not good, and a common problem. STOP now and get a good inspection and get it fixed if my theory is correct. The farther it goes, the more expensive it gets!
Old Jul 20, 2008 | 12:46 PM
tonylittell
that doesnt sound good... what is the fix for it?
To drive belt problems
