C-5 seat track question
Old Jul 20, 2008 | 11:00 PM
1Fordman's Avatar
1Fordman
Default C-5 seat track question
Will passenger side manual seat tracks work on a drivers side seat? I'm putting C-5 seats in my 68 and because of the difference in headroom have to go with manual tracks. Seat belt mounting is not an issue as the C-3 belts mount to floor mounted hardware.
Old Jul 21, 2008 | 03:06 PM
earnhardtJR's Avatar
earnhardtJR
From what I understand, the manual passenger seat slider is identical to a manual driver side slider with the exception of the seat belt mount. Since this isn't a problem for you, I think you can just hack off the seatbelt bracket and use it like that.
Someone who has replaced their power driver side seat bracket with a manual one may be able to confirm this- I am planning on doing this swap for some weight savings.
Old Jul 21, 2008 | 11:16 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The C6 manual seat track has studs on both sides for mounting the seat belts, so you can use them on either side.
To C-5 seat track question
