Where can you find the GM A/C O rings at? I need the ones for the left and right side of what I think is the dryer located on the passenger side back of the intake/valve cover. A real pain to get at . I tryed the green ones from autozone but they are not thick enough. I havent called GM yet but not sure if there is a part # for them or is it another thing you have to replace the whole system for
A GM parts dept. is probably your best bet to get the correct ones you need for the dryer inlet and outlet connections.
I bought an o-ring kit at Autozone when I opened up my A/C system last year. I replaced all of the o-rings (except on the evaporator) It's been in service for over a year now with no leaks.
