Z06 DIC trans temp
Old Jul 21, 2008 | 09:51 PM
GO_BLUE_VETTES's Avatar
GO_BLUE_VETTES
Default Z06 DIC trans temp
02 C5 Z06 - MN12
I get high trans temp warnings when RR at the track.
I know how the temp shows up after the high temp warning until you hit exit on the DIC.
I know that you can't get it to come back w/o getting high temps again.
QUESTION: Has anyone figured out how to flash the PCM such that the trans temp guage is displayed in the DIC all the time? (in a C5z)
Old Jul 21, 2008 | 10:21 PM
EStreeter's Avatar
EStreeter
Don't know about the Z06 but on my 03 A4 I just push the guages button until it shows the Trans Fluid Temp. It stays on trans temp all the time if I don't push the button again. If I go to fuel or trip or some other button and then back to guages the trans temp is still there.
Maybe its different with a manual trans?
Old Jul 21, 2008 | 10:25 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
^ Autos are different than manuals... I dont get why GM didnt give us the ability to see trans temp all the time.
You could set the high temp warning threshold low so its up all the time.
EDIT: Only Z06s have trans temp gages... manual C5s dont.
Old Jul 21, 2008 | 10:26 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I've never seen the hi temp for the trans. iIve had my oil at 305, but never a hot trans. You might have a problem
Old Jul 21, 2008 | 10:28 PM
Cobra4B's Avatar
Cobra4B
^ No, no problem. It really depends on the track, driving style, and weather.
I run Amsoil and have my exhaust ceramic coated so Ive never seen it. But my fathers Z16 on stock fluid all stock would get it after 20 min. We wrapped the exhaust in header wrap where it passes under the trans and swapped to Amsoil.
This past weekend at Vipredays at VIR it took 55 min of hard driving in 95 degree weather to see the high trans temp warning. We were drivin the car back to back in 30 min session because our Panozs fuel pump failed.
Old Jul 21, 2008 | 10:36 PM
GeorgeZNJ's Avatar
GeorgeZNJ
So, what is considered hot?, by that I mean at what temp do you see a warning?
Old Jul 21, 2008 | 11:05 PM
Cobra4B's Avatar
Cobra4B
271 I believe... TRANS OVERTEMP WARNING flashes on the DIC then it show you the temp.
Old Jul 21, 2008 | 11:25 PM
GO_BLUE_VETTES
Everybody is right, but how do you change something in the DIC so it shows up ALL the time in a Z06. Something special would have to be done...
Old Jul 21, 2008 | 11:37 PM
Cobra4B's Avatar
Cobra4B
Set the trans temp warning lower in the PCM so it comes up earlier... only downside is you would get a warning message when theres no real warning. Not sure if you can make it accessible like it is in an A4.
To Z06 DIC trans temp
