I was looking at the possibility of replacing my control arms on my C5Z06. The bushings appear to be completely shot, especially on the fronts. I went to the gmpartsdirect catalog and it is a little confusing. They have the Front Lower Control arm in there twice and one of the instances has the "lower ball joint" in there but no price. So, is it that you buy the lower control arm and the upper control arm parts and the lower one comes with the ball joint already in? That would be fine by me as there would be no need to press in the old ball joint.
Thanks Steve. The ball joints are fine as far as I can tell. The bushings are hosed though. I'd put aftermarket bushings in, but I autocross in SCCA SS class and I have to have OEM bushings. So, basically I have to replace the whole control arm. So, it sounds like if I buy the upper control arm lower control arm and it comes with the lower ball joint and keep the old knuckle, I should be fine.
