drives/brakes straight, no pulling on the highway while normal driving. But when the car is at WOT in 3rd & 4th gear it wants to go to the left.
I figure it the torgue that pushing it that way, maybe the right rear tire has more power put to it than the left.
Question: had the car aligned, now is there an adjustment under the car to compensate for this??
Used to fly alot and had some time in my Dad's P-51. The same as the 51, it's torque. Just like when you took off in a 51, you had to compensate for the torque or else you became a smoking hole. You have to do the same with the vette esepcially wwhen you reach the peak.
Watch the left front end of a tractor trailer when they they take off from a stop the whole left side wants to lift and pull that way. Compensate and realize it's going to happen.
From: maple grove and North Port fl mn and now florida
Try driving under the same conditions with the traction control off and see if it still happens. I have to drive with it off at all times or it has a tendency to change lanes in 3rd and 4th. I have a lot of torque. Cheers
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
That's what I like about counter rotating twins - P factor isn't a factor
The P-51 is still my favorite plane. Hats off to you for having flown one.
