Z06 Maf?
Old Jul 22, 2008 | 01:02 PM
Black Out's Avatar
Black Out
Default Z06 Maf?
I'm curious if I could purchase a z06 MAF for a 2002+ and use it on my C5?
I have a 99 C5
Old Jul 22, 2008 | 01:23 PM
MattB's Avatar
MattB
Its not a LS6 MAF, they were used on all Vettes. The 85mm MAF is called the 5 wire MAF because it has the Intake Air Temp sensor built into it, the older versio only had three wires and a seperate IAT. You would need a wiring harness, a new air bridge because the old one will not attach to the larger MAF, and lastly you would need a tune. It will not run well without a tune.
Old Jul 22, 2008 | 01:35 PM
Black Out's Avatar
Black Out
Oh ok thanks for the info... I was just looking at some on ebay and was thinking of getting it if it was an easy HP gain. But thanks for the info.
Old Jul 22, 2008 | 01:38 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
no gains
Old Jul 22, 2008 | 01:43 PM
99C5JA1's Avatar
99C5JA1
To really see a benefit you will want an '01+ air bridge, 90mm throttlebody, 90mm intake, and a filter with a 85mm+ outlet. The intake tract will only flow as much as the smallest restriction, in your case the 78mm throttlebody. Add to that on a stock car you would not see any real power gains with this setup. You will also need a tune to set the MAF table for the new sensor, otherwise it will not run correctly.
The only real benefit to the swap on a stock car would come from the relocation of the IAT sensor. The '97-00 IAT's location in the air bridge causes it to heat soak from the radiator. This causes the PCM to see false heat in the incoming air charge and pull timing. I noticed a nice drop in idle air temps with the 5 wire MAF. Probably not worth the hassle for this benefit.
Old Jul 22, 2008 | 01:53 PM
Black Out's Avatar
Black Out
Alright thanks for all the input, I just installed the vararam intake and thought I could try and pickup some more gains as far as the intake goes on these cars. But thanks for the info.
To Z06 Maf?
