Detonation problem solved, poor fuel
Old Dec 29, 2001 | 02:40 AM
CAracer's Avatar
CAracer
Default Detonation problem solved, poor fuel
I finally solved the detonation problem with my 01 A-4. I was told by my tuner that Mobil is the worst gas to use. I changed to Chevron and the pinging went away. I guess gas brands matter?
I also changed the plugs to NGK's 55 which also helped solve the problem.
Old Dec 29, 2001 | 07:30 PM
odie's Avatar
odie
Default Re: Detonation problem solved, poor fuel (CAracer)
I thought Mobil gas was decent? I normally use Mobil or Chevron and never noticed a difference. Anyone else have problems with Mobil? :confused:
Old Dec 29, 2001 | 09:23 PM
CAracer's Avatar
CAracer
Default Re: Detonation problem solved, poor fuel (odie)
Yes, here in CA the octane is only 91. Where do you live? What octane are you using?
Stay with Chevron it seems to work the best. I also heard Arco isn't that good as well.
Old Dec 29, 2001 | 10:49 PM
odie's Avatar
odie
Here in Florida the octane is 93 so maybe that's why I have not had a problem. I lived in California for a while, so I agree that the ARCO gas is crap.
Old Dec 29, 2001 | 11:19 PM
VERTVETTE's Avatar
VERTVETTE
I also live in florida and never had a problem with mobils 93 octane. I use only mobil or amaco altimate clear also 93 octane and very good fuel. :chevy
Old Dec 30, 2001 | 12:43 AM
ZO6LS6's Avatar
ZO6LS6
CAracer, ditto's.....................100% AGREEMENT...............
I since day 1, have used only Texaco 93, or Chevron 93.......usually Chevron, because the Techcron is GOOD stuff.
Anyway, one day last week, I decided to try some Mobil 93, hadf not driven more than 20 miles, and I get pinging BAD at aound 45-55 in 4th, and 5th gears......
Car has less than 3500 miles on it, and NEVER ever had done this before........went to the Chevron station, filled up..........drove around for a while BINGO........never ANOTHER PING.................
So, no more Mobil for me................ :yesnod:
Old Dec 30, 2001 | 01:43 AM
CAracer's Avatar
CAracer
See, the information is good. Mobil is not up to standard. Watch out for Arco as well.
Use standard if in Ca. Other options are availabe in other states with the higher octane levels.
Old Dec 30, 2001 | 03:16 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
I have used Mobil a few times with no problems :confused:
Old Dec 30, 2001 | 09:16 AM
skydive69's Avatar
skydive69
It is amazing to see how the message changes with the messenger. When I had my Superchip installed at the factory in my SVT Lightning, they told me to run Mobile exlusively. I did, and nary a ping.
Old Dec 30, 2001 | 11:55 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Since the downgrade in fuel to 91 octane happened here in CA. I too have experienced problems with pinging. Chevron fuel has made a difference in my car and I understand the added Techtron additive helps clean the injectors too. If that is the case, it seems that the Chevron Fuel is hard to beat! :)
vetterdstr :cheers:
Old Dec 30, 2001 | 08:07 PM
Closer_2001's Avatar
Closer_2001
Default Re: Detonation problem solved, poor fuel (vetterdstr)
I use Mobil/Exxon 93 only. Because of a situation we will not discuss right now :jester , I saw my engine with the heads/intake removed.
I didn't see a trace of carbon and the plugs look perfect also. :cool: That is after 13,xxx miles.
Old Dec 30, 2001 | 10:48 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: Detonation problem solved, poor fuel (skydive69)
I am convinced.......that Mobil 93 in Dallas, may not be Mobil 93 in Fla, or NJ..........
Exxon used to be one of the very best.........
I have not used any in a long time.......I plan on trying some soon.
Same for Shell Super Shell.................
Also, just because the pump says 93, doesn't mean YOU are actually GETTING 93.............
Depends on WHAT station you use, most here are franchised, no mfgrs stations anymore................just a right to put up the sign, and buy their products......no exclusivity here.......
To Detonation problem solved, poor fuel
